Mysterious clicking under dash
I have a strange clicking sound under the dash when moving. Does not seem to be tied to engine/trans.
clicks accelerate/decelerate with wheel speed. Click is also accompanied by a blip in the aux gauges (all of them in sync blip up/down slightly with the click).
any thoughts?
https://youtube.com/shorts/9a2DiIoXHBw?si=2fdSqPCSib6KNyR8
any thoughts?
Def not 02 counter - it is unplugged.
I had replaced the odo gear about 20k ago, but…
Wayne suggested there may be a link there. Well when I stopped at a light I reset the odo - the gauges dipped a bit when I pressed the reset and the voltage dropped a LOT…like a short maybe somewhere in the reset circuit. I do have the lutz boards on my gauges.
any thoughts?
https://youtube.com/shorts/9a2DiIoXH...dSqPCSib6KNyR8
any thoughts?
All my 928s exhibit similar behavior on odometer reset. The solenoid VDO used in these clusters are way overpowered and violently yank at the odometer reset bar
9two8 (12-05-2023)
Well - I thought the switch was the issue but it turns out it is not. The click is still there along with the gauge blip - even with the switch removed. Somehow somewhere something is being grounded at a regular interval that is directly connected to speed of a wheel turning - and it is showing its path in one of the cluster grounds. I guess the next step is to get the car off the ground and start the engine and go around and see if we can determine the source of the grounding by manually turning each wheel and watching the gauges of listening for the click.
