Any suggestions on getting these two together? I started using a soft blow hammer on the end of the torque tube bar (not the tube).
I don't want to mess up the bearing placement, so I'm going to wait for some suggestions.
Yes. The clamp is loose.
What do you got?
NOTE in that picture from post 1 it appears the rear pinch bolt is still installed.
The bolt must not be installed to fit the shaft.
That said if the shaft wont fit then one of the fingers of the input collar must be bent.
NOTE the shaft must be perfectly lined up to slide into this input collar.
