The gauge I provide with my kit is stainless steel, liquid filled, 0-100psi with 1/4npt brass connection. Included is a custom fitting with 1/4npt on one end and metric threads on the other end to fit on the fuel rail. For the seal I use an o-ring that fits into a machined groove on the fitting and against the fuel rail. You can tighten it finger tight and it won't leak. Here is a picture of what it looks like.
Hello Mr. Tim Murphy. Do you use- WIKA-Guages? And if you do I'll vouch for them.Excellent quality and built to withstand H2S. We use them all the time on our hydrogen sulfide recovery systems. Mike.
I used a Defi gauge w/electronic sender...
Your choice w/ many options. I used a rail gauge b4 and will suite your needs well. It will work well for a few years.
Truly, if you need to check your FP... just buy a FP tester, and use it as needed.
Photos of my solution to the fuel pressure gauge mounting problem are here. We cut a relief in the flat end of the nut to hold an o-ring against the fuel rail.
