Valve cover
Hey guys,
changed the seals ears on my valve covers. Went back to review Dewayne’s write-up and found I forgot to add gasket sealer Around the spark plug seals (I applied it on the side of the gasket to valve cover) but not around the gasket to engine. Will it leak into the spark plug hole?
Received 1,320 Likes
Yes.
I didn't put any sealant and it's leaking. Not much but leaking. Did the job about ten years or so ago.
I will put some sealant there for sure next time.
Bertrand Daoust (09-02-2023)
Team Owner
UMM make sure to also add the 23 sealing washers to the bolt heads this will add clamping force to the seals
I would suggest to use dreibond 1209 on the seals
