Plasti-Dip Paint Job
It was a really simple process. I used the medium kit and got their standard accessory kit, which included enough tape and such to do everything. The medium kit comes with 2 gallons of primer and 3 gallons of color. Overall, I put roughly 8 coats (4 primer and 4 color) on with the primer being thinner and laying the color on a little heavier. I used the standard DYC sprayer and it worked really well. It says to wait 20 minutes between coats, but I waited roughly 10 - 15. The hardest part is prep and then making sure the carefully pull the tape out so you do not tear the paint. A razor blade is very handy for this part. There are a few spots that I rushed and peeled a little paint. Unfortunately, there is no good way to touch this up because the paint is very thin so it can be sprayed.
