LEDs
If you want LEDs in your dash I recommend the Lutz board which would replace that flimsy decrepit old printed circuit film. I just did that on my 78 and I'm very happy with the results. The LEDs are definitely not too bright from that board as they are sized appropriately. Check out my two videos on scopers garage YouTube channel for step by step instructions.
This will help you.
You SHOULD have all of the bases, unless things are missing, but..I highly doubt that.
Check the first photo in this thread, you can see that new bulbs just slide into the old bases.
I noted here that when I thought to put an ohm meter on the "good" bulbs that were in there for 37ys, I got some really high readings on some..they worked, but for sure were "dark".
If you wanna go the extra mile..polish the panel
Photo credit Rob Edwards
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/900x1200/359975261_1418454252331780_6681577615860082081_n_15b7aa0b8f0a55228e99c6d6d8b631d727858645.jpeg)
https://rennlist.com/forums/928-foru...-foil-day.html
Good info. will seriously consider buying that lutz kit. of course it will sit on a shelf like so many other projects...but should get at it before next NY inspection.
Currently debating painting part of the house or...repairing the track adjuster on my Takeuchi TB250
Speedtoys (08-11-2023)
To add an unsolicited comment, I think the printed circuit boards that Lutz makes are well put together and have worked for me without issue. I've had one on my '85 for close to a year and it works without issue. I'm probably a bit biased, but i couldn't see me trying to replace the old foil when circuit boards exist.
The LEDs upgrades are just a bonus and look very nice in the pod.![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
