Part Number Help - Rear Hatch Plastic Square thingy
I'd like to replace the little plastic squares that are attached to the hatch, right in front of the adjustable rubber pieces that sit about halfway on the side of the hatch. PET shows it as Part #36 on the diagram (803-05) but it seems that the description didn't make it down into the parts list.
Any ideas, or what I can/should use to substitute?
This is a little hard to see, but you can tell where the little protector thing used to be:
Blurry, but you can see where it is supposed to be
#36 in PET
I'll get some PPF, I like that idea. Thanks, Stan.
ETA: Also, I'm an idiot and neglected to check the PET pdf for the years following; I had only checked the prior years. In the 1992 - 1995 PET, it shows up at #41, PN 928 512 531 02.
D'oh!
Cheers
#36 in PET
D'oh!
Cheers
