Vacuum hose questions
I have looked at a couple of the vacuum hose diagrams, but I am still not sure which ones I am looking at. I have checked the 4 hoses that connect to this connector in the photo (this connector is just by the brake servo, attached to the firewall) - and the extra hose in the picture is part of my test kit:
I am guessing that the white hose in the middle is heading for the reservoir?
What are the other hoses for? In the short term, I guess I might as well cap the connector for the grey hose, so that the other hoses have full strength?
Are any of these heading to the HVAC – as my heater controls are working but might be slower and less effective than they should be?
- The “feed” hose from the front of the engine has a healthy vacuum when the engine is running.
- The black hose at the bottom holds good vacuum.
- The white hose in the middle needs lots of pumping but holds the vacuum.
- The grey hose at the top heads under the fuel rail and holds no vacuum.
Archive Gatekeeper
Here's an annotated diagram from John Pirtle's excellent writeup on the S4+ HVAC vacuum controls:
sprie (06-09-2023)
Team Owner
NOTE picture for the 928 S is the same except the port for the flappy supply is plugged.
Thank you,
in the cross on my 86 S is a bolt, so it's on the right location!
I must look if the Y connector is there or someone blocked the cruise control.
