Alternative in-car ISV/IAC quick test
Requirements: A floating (i.e. the negative output should not be connected to chassis ground) 5-12 volt power source (variable power supply, 9V battery, USB power pack, etc.) and a helper.
1. [Optional] Disconnect 12V battery. Not strictly necessary, but may reduce electrical stress on the LH when the plug is disconnected.
2. Pop the hood / bonnet open
3. Unplug the 35-pin plug to the LH. If you want, you can unplug the EZK also, but it is not necessary.
4. Touch positive lead of the power source to pin 9 of the LH plug. Touch negative lead of the power source to pin 33 of the LH plug. Have your helper listen for a clunk or thunk near the intake manifold.
Caveats: This only tests if the ISV/IAC armature moves. It won't tell you if it has friction from rust, or if the input or output rubber hoses are cracked.
At 6 volts, my ISV drew 0.6 amps. ISV/IAC resistance (between pins 9 & 33 of the LH plug) measures 8.4 ohms. Not sure if these are normal values, but it made a satisfying clunk when energized.
Photo borrowed from Rob Edwards (Note: This is the LH plug from a '90 or later 928. '87-'89 have the cable going into the top side of the connector, but the pinout is the same):
