85 TPS Wiring Question
Team 928,
My TPS connector cracked and came apart during my Top Engine Refresh. Unfortunately, I cant make out where the wires go in the connector.
The end coming from the engine harness has white/red brown and white blue.... The other end coming from the TPS has blue, black and yellow wires. I can't for the life of me figure out which connects to what. I know brown is ground, but what does each wire correspond to on the other end?
I pulled the ETM and don't see my answer. The pic I have is attached. PLEASE HELP!
Team Owner
call Roger and order a new short TPS harness,
odds are if the connector crumbled the wires inside are pretty dirty/ corroded
RennHarry (03-26-2023)
Team Owner
OOPs forgot to add,
if the TPS harness is toast,
then the CPS is as well,
only order a Bosch replacement
