Advice/counsel requested - lots of freshly yellow cad plated parts to sell
It's a really good question, Chuck (And beautiful plating, wish we could get cad like that in SoCal without buying an aerospace company as a front....)
You'll note that neither Mark nor Roger market hardware kits for any particular application, as it just doesn't make financial sense for the time it takes to measure, match, and package everything you'd need, and be confident that it's right. There are so many variations from year to year and even within years given particular option sets. And there's the slippery slope problem that if you're OCD enough to replate and rebuild your throttle quadrant, that you didn't also replace all the hardware nearby will drive one nuts (no pun intended).
As to pricing, it's also a narrow market because of how frickin' expensive the non-standard brackets are. For instance those throttle quadrants- A new one from Porsche is $140 (if they're even available), the three levers are $45 each, and six HK0810 bearings are $50, at least. So that's $325 for new. Figure half if you bought one used from Mark, but then you paid to cad plate it, and spent an hour (at least) pressing the new bushings in and making sure you got the wave washer stack assembled correctly. So those throttle quadrants are easily worth $200 each, particularly if there's no grooving on the shafts.
The suspension eccentrics, the exhaust hangers, the S4 exhaust clamps, those pieces are all $10-40, new. Half that used, but now they're beautifully plated. So more than half.
So it's the trifecta of many pieces being very valuable, very little of it being the perfect pile for a given application, and it being a ton of time and effort to do the sorting to see if you have everything someone needs for a given application. Small needle to thread.
Got any 56/58/61/62 radiator clamps?
Can always count you Jeff to poo poo on something I post... For the record, retail price on new parts from Roger is $336.10 + tax + shipping so not sure what your definition of right around retail is but, $80+ is not all that close in my book.
Archive Gatekeeper
For what it's worth, if you're going to go into the business of supplying hardware kits, here's one approach to how you'd start.
Nearly every piece of hardware in the Porsche parts system starts with either a 900 number if its specs are called out under a DIN standard, or 999 if they're not.
So first you'd digitize the PET catalog for a given year and model (1989) in this case. Then you'd list all the 900 parts, and the 999 parts. Then you'd discover that a lot of hardware starts with an N part number and you'd add that. Then you'd have to measure everything on the car because most of the PET listings don't give you bolt lengths, or washer thicknesses. Then you'd have to annotate all that.
So here's all the 900, 999 and N-part numbers for an '89 GT. Along with the PET diagrams you could kinda-sorta put together kits for an '89 GT, but would they be complete for an '89 automatic? Sometimes yes, sometimes no. Now do this multiple time for each major year, engine, and transmission variant from '78-95. It'd be an enormous amount of work and a never-ending series of followups for the one or two things that got missed.
Code:
Part Number Name Notes Qty 803 817 121 "washer B 6,4" 1 803 955 437 washer 2 803 955 437 "washer B 8" 1 900 012 070 00 "straight pin 12 X 18" rear block dowel pins 2 900 012 086 00 "straight pin 6 X 18" 2 900 014 066 02 "pan-head screw M 5 X 18" waterpump timing arrow mounting screw 2 900 025 001 02 "washer A 3,2" 5 900 025 002 02 "washer A 4,3" 4 900 025 002 02 "washer A 4,3" 4 900 025 002 02 "washer A 4,3" /LL 2 900 025 002 02 "washer A 4,3" 4 900 025 003 02 "washer A 5,3" 1 900 025 003 02 "washer A 5,3" 2 900 025 003 02 "washer A 5,3" 5 900 025 003 02 "washer A 5,3" "6 6" 900 025 003 02 "washer A 5,3" 4 900 025 003 02 "washer A 5,3" Black plastic spacer washer 15x 5.8 x 3.5 2 900 025 003 02 "washer A 5,3" 2 900 025 003 02 "washer A 5,3" 1 900 025 003 02 "washer A 5,3" 4 900 025 003 02 "washer A 5,3" 2 900 025 003 02 "washer A 5,3" 1 900 025 003 02 "washer A 5,3" 4 900 025 003 02 "washer A 5,3" 4 900 025 003 02 washer A5.3 900 025 007 02 "washer A 8,4" washer for M8 girdle bolts 24 900 025 007 02 "washer A 8,4" 8 900 025 007 02 "washer A 6,4" 6 900 025 007 02 "washer A 8,4" 1 900 025 007 02 "washer A 8,4" 1 900 025 007 02 "washer A 8,4" 1 900 025 007 02 "washer A 8,4" 2 900 025 007 02 "washer A 8,4" 2 900 025 007 02 "washer A 8,4" 4 900 025 007 02 "washer A 8,4" 1 900 025 007 02 washer 4 900 025 007 02 washer 4 900 025 007 02 "washer A 8,4" 1 900 025 007 02 "washer A 8,4" 12 900 025 007 02 "washer A 8,4" 12 900 025 007 02 "washer A 8,4" 1 900 025 007 02 "washer A 8,4" 2 900 025 007 02 "washer A 8,4" 8 900 025 007 02 "washer A 8,4" 5 900 025 007 02 "washer A 8,4" 4 900 025 007 02 "washer 8,4" 4 900 025 007 02 "washer 8,4" -90 4 900 025 007 02 "washer 8,4" 10 900 025 007 02 "washer A 8,4" 12 900 025 007 02 "washer A 8,4" 90- 1 900 025 007 02 "washer 8,4" 2 900 025 007 02 "washer A 8,4" 4 900 025 007 02 "washer A 8,4" 1 900 025 007 02 "washer A 8,4" 4 900 025 007 02 "washer A 8,4" 1 900 025 007 02 "washer A 8,4" 2 900 025 007 02 "washer A 8" 2 900 025 008 02 "washer A 10,5" 4 900 025 008 09 "washer A 10,5" Peripheral girdle M10 washers 2 900 025 008 09 washer TB tensioner push rod washer 1 900 025 008 09 "washer B 10" /LL 1 900 025 008 09 "washer A 10,5" 8 900 025 008 09 "washer A 10,5" 4 900 025 008 09 "washer A 10,5" 6 900 025 008 09 "washer A 10,5" rear sway bar 6 900 025 008 09 "washer A 10,5" "/LL /LL" 1 900 025 008 09 "washer A 10,5" 1 900 025 008 09 "washer A 10,5" 3 900 025 008 09 "washer A 10,5" 3 900 025 008 09 "washer A 10,5" 1 900 025 008 09 "washer A 10,5" 7 900 025 009 02 "washer A 13" 1 900 025 009 02 "washer A 13" 2 900 025 009 02 "washer A 13" 2 900 025 014 02 "washer B 6,4" 2 900 025 020 02 "washer A 17" 2 900 025 044 07 "washer A 4,3" 6 900 025 045 02 "washer 6,4" 3 900 025 049 07 "washer A 4,3" 8 900 025 049 07 "washer A 4,3" 8 900 027 011 01 "lock ring B 4" -88 16 900 027 015 02 "lock ring B 8" X 900 027 015 02 "lock ring B 8" 2 900 027 015 02 "lock ring B 8" 2 900 027 015 02 "lock ring B8" 1 900 027 016 02 "lock ring B 10" 4 900 027 016 02 "lock ring B 10" -89 1 900 027 016 02 "lock ring B 10" 2 900 028 005 02 "spring washer A 10" 4 900 028 006 01 "washer A 3" 1 900 028 007 02 "spring washer B 5" 3 900 028 014 02 spring washer 4 900 028 019 08 "spring washer B 7" 8 900 029 001 10 "winged nut M 5" 4 900 029 001 10 "winged nut M 5" rear side marker wing nut 2 900 031 001 02 "washer 8,4" 2 900 031 001 60 "washer 8,4" red fiber washer for door contact pin switch 2 900 031 011 02 washer 1 900 031 025 0A "washer 8,4" support for stillborn 3-pin connector by CO sampling tubes 3 900 031 028 07 "washer 6,4" 2 900 034 003 02 "hexagon nut M 10" 1 900 034 003 02 "hexagon nut M 10" 1 900 034 013 02 "hexagon nut M 16 X 1,5" 2 900 034 013 02 "hexagon nut M 16 X 1,5" 1 900 036 014 02 cover freeze plug for cylinder head 2 900 040 013 02 cover plate 3 900 040 013 02 cover plate 1 900 041 047 01 "circlip 55 X 2" 1 900 042 030 02 circlip rear wheel bearing circlip 2 900 067 008 02 "pan-head screw M 6 X 12" 1 900 067 008 02 "pan-head screw M 6 X 12" 4 900 067 011 02 "pan-head screw M 6 X 20" X 900 067 011 02 "pan-head screw M 6 X 20" 4 900 067 057 02 "pan-head screw M 8 X 20" 2 900 067 081 02 "pan-head screw M 8 X 35" 2 900 067 081 02 "pan-head screw M 8 X 35" 2 900 067 084 02 "pan-head screw M 12 X 110" 2 900 067 084 02 "pan-head screw M 12 X 110" 2 900 067 089 02 "pan-head screw M 6 X 22" 4 900 067 089 02 "pan-head screw M 6 X 25" -88 1 900 067 117 0A "hexagon socket head bolt M 6 X 16" 4 900 067 123 01 "pan-head screw M 10 X 50" rear axle socket head cap screws 12 900 067 124 02 "pan-head screw M 10 X 35" 2 900 067 147 02 "pan-head screw M 8 X 25" 1 900 067 154 02 "pan-head screw M 12 X 1,5 X 70" S4 front caliper mounting SHCS 4 900 067 185 07 "pan-head screw M 6 X 12" 2 900 067 248 02 "hexagon socket head bolt M 8 X 70 Z1" 1 900 067 255 02 "pan-head screw M 5 X 12" 2 900 067 269 02 "screw M 6 X 16" 4 900 067 269 0A "pan-head screw M 6 X 16" 2 900 067 270 0A "pan-head screw M 6 X 25" 16 900 067 271 09 "screw M 8 X 20 Z 1" 2 900 067 276 02 "hexagon socket head bolt M 8 X 35 Z1" 3 900 067 284 02 "pan-head screw M 8 X 53" 9 900 070 002 02 "cap nut M 6" -89 2 900 072 003 02 "adjusting screw M 5 X 12" 2 900 074 015 02 "hexagon-head bolt M 6 X 30" 2 900 074 015 02 "hexagon-head bolt M 6 X 30" 2 900 074 015 02 "hexagon-head bolt M 6 X 30" 4 900 074 049 02 "screw M 8 X 110" air pump mounting bolt 1 900 074 049 02 "screw M 8 X 110" 1 900 074 063 02 "hexagon-head bolt M 10 X 55" 2 900 074 111 02 "hexagon-head bolt M 6 X 50" 2 900 074 134 02 "hexagon-head bolt M 8 X 45" 1 900 074 139 02 "hexagon-head bolt M 8 X 55" TB tensioner roller bolt 1 900 074 139 02 "hexagon-head bolt M 8 X 55" 2 900 074 195 02 "hexagon-head bolt M 8 X 100" 90- 3 900 074 197 02 "hexagon-head bolt M 10 X 130" 1 900 074 197 02 "hexagon-head bolt M 10 X 130" 1 900 074 283 02 "hexagon-head bolt M 8 X 45" 1 900 074 283 02 hexagon-head bolt 1 900 074 287 02 "hexagon-head bolt M 8 X 35" 5 900 074 287 02 "hexagon-head bolt M 8 X 35" 6 900 074 287 02 hexagon-head bolt 6 900 074 292 02 "hexagon-head bolt M 10 X 98" 2 900 074 304 02 "hexagon-head bolt M 8 X 60" 2 900 074 321 02 "hexagon-head bolt M 8 X 40" 90- 1 900 074 321 0A "hexagon-head bolt M 8 X 40" 4 900 075 010 02 "hexagon-head bolt M 6 X 12" 1 900 075 014 02 "hexagon-head bolt M 6 X 18" 6 900 075 014 02 "hexagon-head bolt M 6 X 18" 5 900 075 014 02 "hexagon-head bolt M 6 X 18" 2 900 075 014 02 "hexagon-head bolt M 6 X 18" 1 900 075 014 02 "hexagon-head bolt M 6 X 18" 90- 4 900 075 014 02 "hexagon-head bolt M 6 X 18" 1 900 075 014 02 "hexagon-head bolt M 6 X 18" 1 900 075 014 02 "hexagon-head bolt M 6 X 18" 3 900 075 014 02 "hexagon-head bolt M 6 X 18" 1 900 075 016 02 "hexagon-head bolt M 6 X 22" bolt for cam cap sealing plug 5 900 075 016 02 "hexagon-head bolt M 6 X 22" 12 900 075 016 02 "hexagon-head bolt M 6 X 22" 2 900 075 016 02 "hexagon-head bolt M 6 X 22" 4 900 075 017 02 "hexagon-head bolt M 6 X 25" 2 900 075 017 02 "hexagon-head bolt M 6 X 25" 3 900 075 041 09 "hexagon-head bolt M 10 X 25" 1 900 075 043 02 "hexagon-head bolt M 10 X 30" /LL 1 900 075 043 02 "hexagon-head bolt M 10 X 30" /RL 4 900 075 043 02 "hexagon-head bolt M 10 X 30" /LL 3 900 075 057 02 "hexagon-head bolt M 6 X 16" 4 900 075 057 02 "hexagon-head bolt M 6 X 16" 2 900 075 057 02 "hexagon-head bolt M 6 X 16" 2 900 075 057 02 "hexagon-head bolt M 6 X 16" 2 900 075 057 02 "hexagon-head bolt M 6 X 16" 90- 2 900 075 057 02 "hexagon-head bolt M 6 X 16" 3 900 075 057 02 "hexagon-head bolt M 6 X 16" 2 900 075 057 02 hexagon-head bolt 1 900 075 057 02 "hexagon-head bolt M 6 X 16" 2 900 075 079 02 "hexagon-head bolt M 8 X 22" 1 900 075 079 02 "hexagon-head bolt M 8 X 22" 1 900 075 079 02 "hexagon-head bolt M 8 X 22" 1 900 075 085 02 "hexagon-head bolt M 8 X 20" 2 900 075 085 02 "hexagon-head bolt M 8 X 20" 4 900 075 085 02 "hexagon-head bolt M 8 X 20" 2 900 075 087 02 hexagon-head bolt 4 900 075 099 02 "hexagon-head bolt M 8 X 30" M8 girdle bolts 6 900 075 099 02 "hexagon-head bolt M 8 X 30" 8 900 075 099 02 "hexagon-head bolt M 8 X 30" 12 900 075 099 02 "hexagon-head bolt M 8 X 30" 12 900 075 099 02 "hexagon-head bolt M 8 X 30" 6 900 075 128 02 "screw M 8 X 20" 3 900 075 145 02 "hexagon-head bolt M 5 X 16" 2 900 075 145 02 "hexagon-head bolt M 5 X 15" 1 900 075 222 02 screw 91- 4 900 075 230 10 "hexagon-head bolt M 4 X 16" 4 900 075 260 02 "hexagon-head bolt M 6 X 16" 1 900 075 260 02 "hexagon-head bolt M 6 X 15" 4 900 075 260 02 "hexagon-head bolt M 6 X 15" 2 900 075 291 02 "screw M 6 X 16" 3 900 075 309 08 "hexagon-head bolt M 8 X 20" 4 900 075 312 02 "hexagon-head bolt M 6 X 12" 3 900 075 338 02 "hexagon-head bolt M 6 X 25" 2 900 075 339 08 "hexagon-head bolt M 8 X 30" -90 4 900 075 339 08 hexagon-head bolt -90 4 900 075 341 02 "screw M 6 X 25 Z1" Oil pan bolts 5 900 075 341 02 "screw M 6 X 25" 8 900 075 341 02 "screw M 6 X 25 Z1" 2 900 075 343 02 "hexagon-head bolt M 6 X 45" 4 900 075 344 02 "hexagon-head bolt M 6 X 50 Z1" 2 900 075 346 02 "hexagon-head bolt M 6 X 40" 1 900 075 347 02 "screw M 6 X 28 Z1" Oil pan bolts 25 900 075 355 02 "screw M 6 X 16 Z1" 1 900 075 357 02 "screw M 6 X 12 Z1" 1 900 075 357 02 "screw M 6 X 12" 5 900 075 357 02 "screw M 6 X 12" 5 900 075 358 02 "hexagon-head bolt M 8 X 20" 1 900 075 361 02 "hexagon-head bolt M 5 X 12" 1 900 075 366 02 "hexagon-head bolt M 8 X 16" 900 075 398 02 "hexagon-head bolt M 8 X 16 SB" 1 900 076 010 02 hexagon nut 2 900 076 010 02 "hexagon nut M 6" 4 900 076 010 02 "hexagon nut M 6" 4 900 076 010 02 "hexagon nut M 6" 12 900 076 010 02 hexagon nut 1 900 076 010 02 "hexagon nut M 6" 2 900 076 010 02 "hexagon nut M 6" 2 900 076 010 02 "hexagon nut M 6" 2 900 076 010 02 "hexagon nut M 6" 2 900 076 010 02 "hexagon nut M 6" 4 900 076 010 02 "hexagon nut M 6 see group" 1 900 076 010 02 "hexagon nut M 6" 4 900 076 010 02 "hexagon nut M 6" 2 900 076 010 02 hexagon nut 1 900 076 010 02 "hexagon nut M 6" -89 6 900 076 010 02 "hexagon nut M 6" 4 900 076 010 02 "hexagon nut M 6" 1 900 076 010 02 "hexagon nut M 6" 1 900 076 010 02 "hexagon nut M 6" 2 900 076 025 02 "hexagon nut M 8" 1 900 076 025 02 "hexagon nut M 8" 2 900 076 025 02 "hexagon nut M 8" 1 900 076 025 02 "hexagon nut M 8" 1 900 076 025 02 "hexagon nut M 8" 1 900 076 025 02 "hexagon nut M 8" 1 900 076 025 02 "hexagon nut M 8" 1 900 076 025 02 "hexagon nut M 8" 6 900 076 025 02 "hexagon nut M 8" 90- 1 900 076 025 02 "hexagon nut M" /LL 2 900 076 025 02 "hexagon nut M 8" 4 900 076 025 02 "hexagon nut M 8" 1 900 076 025 02 "hexagon nut M 8" 1 900 076 025 02 "hexagon nut M 8" 1 900 076 025 02 hexagon nut 1 900 076 025 02 hexagon nut 2 900 076 025 02 "hexagon nut M 8" 1 900 078 006 01 "hexagon nut M 16" 1 900 078 007 02 "hexagon nut M 18 X 1,5" 1 900 082 020 09 hexagon-head bolt 1 900 082 039 02 "hexagon-head bolt M 12 X 1,5 X 100" 4 900 082 044 02 "hexagon-head bolt M 12 X 1,5 X 125" 2 900 082 048 08 "hexagon-head bolt M 12 X 1,5 X 80" 4 900 082 077 02 "hexagon-head bolt M 12 X 1,5 X 37 X 20" 4 900 083 026 02 "hexagon-head bolt M 10 X 1,25 X 20" 1 900 083 036 02 "hexagon-head bolt M 18 X 1,5 X 45" crank bolt 1 900 083 048 02 "hexagon-head bolt M 10 X 1,25 X 40" 90- 1 900 083 057 02 "hexagon-head bolt M 10 X 33" 2 900 083 057 02 "hexagon-head bolt M 10 X 33" 2 900 083 059 02 "hexagon-head bolt M 10 X 45" 1 900 083 059 02 "hexagon-head bolt M 10 X 45" 1 900 084 004 02 "hexagon nut NM 8" 3 900 084 004 02 hexagon nut 1 900 084 004 02 "hexagon nut M 8" 1 900 084 020 02 "lock nut M 4" -90 1 900 085 014 07 "cap nut M 6" 4 900 089 005 02 "washer 6" 4 900 089 006 02 "washer A 8,4" 1 900 091 001 00 "dowel pin 3 X 8" 1 900 091 001 00 "dowel pin 3 X 8" 1 900 095 007 00 "roll pin 3 X 12" 1 900 095 007 00 "roll pin 3 X 12" 1 900 095 036 02 "tensioning sleeve 2 X 8" 1 900 095 072 01 "tensioning sleeve 6 X 12" cylinder head to deck roll pins 2 900 095 085 02 spiral clamping pin roll pins holding headlight swiveling base on lateral shafts 4 900 096 014 02 cap nut cap nuts for mounting passenger side airbag cover 4 900 102 009 00 cutting ring 2 900 104 020 02 union nut 1 900 108 020 00 "ball 6 MM" 2 900 108 020 00 ball 1 900 108 022 00 "ball 9 MM" fuel rail pressure connection ball 1 900 114 015 01 "shake-proof washer A 3,7" 2 900 115 013 01 "serrated lock washer see technical information GR. X NR. 15" 2 900 115 013 01 "serrated lock washer see technical information GR. X NR. 15" 2 900 116 001 07 lock washer 2 900 116 002 01 lock washer 2 900 116 003 02 circlip 1 900 116 005 02 lock washer 1 900 116 009 01 "lock washer 6" 2 900 117 055 00 key S4 cam woodruff key 2 900 118 014 00 woodruff key 1 900 119 004 02 "pan-head screw M 8 X 30" starter mounting bracket bolts 2 900 119 035 02 "pan-head screw M 6X8" door lock cylinder mounting SHCS 2 900 119 052 02 "pan-head screw M 8 X 16" 2 900 119 053 02 "pan-head screw M 10 X 16" 4 900 120 040 02 rivet handbrake handle rivet 1 900 123 005 20 "sealing ring A 12 X 16" 2 900 123 006 30 sealing ring 1 900 123 007 30 "sealing ring A 14 X 18" 1 900 123 011 30 sealing ring 1 900 123 011 30 sealing ring 1 900 123 033 20 sealing ring 2 900 123 042 20 "sealing ring 14 X 18" Copper crush washers 14 x 18 at pressure line on power steering pump and at rack banjo bolts 4 900 123 043 30 "sealing ring A 12 X 15,5" 8 900 123 043 30 "sealing ring A 12 X 15,5" X 900 123 043 30 sealing ring 2 900 123 043 30 "sealing ring A 12 X 15,5" 1 900 123 050 30 sealing ring 4 900 123 050 30 sealing ring 6 900 123 050 30 sealing ring 8 900 123 055 30 "sealing ring A 12 X 16" 1 900 123 060 30 "sealing ring A 24 X 29" oil pressure relief plug sealing ring 1 900 123 060 30 "sealing ring A 24 X 29" 1 900 123 060 30 "sealing ring A 24 X 29" 1 900 123 060 30 "sealing ring A 24 X 29" 2 900 123 115 30 "sealing ring A 8 X 11,5" 1 900 123 118 30 "sealing ring A 22 X 27" oil cooler hose threaded insert to block sealing ring 2 900 123 118 30 "sealing ring A 22 X 27" 1 900 123 118 30 "sealing ring A 22 X 27" 3 900 123 140 30 "sealing ring A 18 X 22" oil pressure bypass valve plug sealing ring 1 900 123 143 70 "sealing ring C 48 X 55" oil pressure sender housing cover sealing ring 1 900 123 143 70 "sealing ring A 48 X 55" 1 900 123 144 30 sealing ring valve cover bolt sealing washers 12 900 123 144 30 sealing ring 12 900 123 144 30 sealing ring 12 900 123 149 70 "sealing ring A 22 X 29" 1 900 124 008 02 "screw plug M 12 X 1,5" 8 900 134 007 02 banjo bolt power steering banjo bolts at rack 2 900 134 014 02 "banjo bolt A 10" 1 900 142 002 01 "lock ring A 8" 1 900 143 001 02 "tapping screw B 2,9 X 6,5" 2 900 143 003 00 tapping screw 6 900 143 004 00 cross recess screw 900 143 007 02 "tapping screw B 4,2 X 13" 4 900 143 013 02 "oval-head sheetmetal screw B 2,9 X 16" 2 900 143 019 07 "oval-head sheetmetal screw B 4,8 X 22" 2 900 143 019 07 "oval-head sheetmetal screw B 4,8 X 22" 7 900 143 031 02 "oval-head sheetmetal screw B 4,2 X 9,5" 1 900 143 031 02 "oval-head sheetmetal screw B 4,2 X 9,5" 4 900 143 034 07 "oval-head sheetmetal screw 3,9 X 19" 2 900 143 046 07 "tapping screw B 4,8 X 16" 6 900 143 047 07 "tapping screw B 4,2 X 19" 16 900 143 047 07 "tapping screw B 4,2 X 19" 32 900 143 065 07 "tapping screw B 2,9 X 9,5" 14 900 143 077 02 "tapping screw B 4,2 X 32" 8 900 143 084 07 oval-head sheetmetal screw 4 900 143 084 07 oval head sheet metal screw 900 143 085 07 "tapping screw B 4,2 X 16" 12 900 143 104 02 "oval-head sheetmetal screw BZ 3,5 X 9,5" 2 900 143 113 07 "tapping screw B 4,2 X 13" 6 900 143 113 07 "tapping screw B 4,2 X 13" 2 900 143 114 07 "tapping screw B 3,5 X 9,5" 2 900 143 118 02 "tapping screw B 4,8" 4 900 143 121 07 "tapping screw B 4,2 X 16" 2 900 143 121 07 "tapping screw B 4,2 X 16" 8 900 143 134 00 "tapping screw BZ 4,2 X 9,5" 4 900 143 134 00 "tapping screw BZ 4,2 X 9,5" 4 900 143 135 07 "tapping screw B 4,2 X 45" 8 900 143 143 02 "tapping screw B 4,2 X 16" 90- 1 900 143 147 07 "tapping screw B 4,8 X 16" -90 5 900 143 147 07 "tapping screw B 4,8X16" -90 11 900 143 147 07 "tapping screw B 4,8 X 16" -89 3 900 143 147 07 "tapping screw B 4,8 X 16" 6 900 143 147 07 "tapping screw B 4,8 X 16" 2 900 143 148 07 "tapping screw B 4,8 X 19" 2 900 143 155 02 "screw B 4,8 X 32 ZI" 1 900 143 164 02 "screw BZ 4,2 X 13 Z1" 91- 1 900 144 008 02 "counters. head tapp. screw B 3,5 X 9,5" 2 900 144 017 07 "tapping screw B 2,9 X 13" 6 900 144 017 07 tapping screw 2 900 144 033 07 "tapping screw B 4,2 X 13 F >>92HS8 40080 F >>92HS8 49560 F >>92HS8 60065" 2 900 144 033 07 "tapping screw B 4,2 X 13 F >>92HS8 40080 F >>92HS8 49560 F >>92HS8 60065" 2 900 144 034 07 "tapping screw B 4,2 X 16" 10 900 144 035 07 "tapping screw B 4,2 X 19" 2 900 145 016 07 "tapping screw 4,2 X 19" 6 900 145 016 07 "tapping screw 4,2 X 19" 90- 4 900 145 044 07 tapping screw -88 4 900 145 062 07 "tapping screw B 3,5 X 25" 5 900 145 091 07 "tapping screw B 4,8 X 32" 2 900 145 097 07 "tapping screw B 3,5 X 16" 2 900 145 099 07 "rais. counters. h. tap. s. B 4,9 X 13" 2 900 146 011 02 "oval-head screw M 4 X 10" 4 900 146 025 02 "screw M 4 X 18" 2 900 146 032 02 "oval-head screw AM 3,5 X 10" 2 900 146 109 00 "oval-head screw M 5 X 12" 2 900 146 114 07 "screw M 3,5 X 8" 3 900 151 001 02 "washer 4,3" 2 900 151 001 02 "washer A 4,3" -88 16 900 151 002 07 "washer A 5,3" 2 900 151 002 07 "washer A 5,3" 3 900 151 002 07 "washer A 5,3" 1 900 151 003 02 "washer A 6,4" 2 900 151 003 02 "washer A 6,4" 4 900 151 003 02 "washer A 6,4" 4 900 151 006 0A "washer B 6,4" 4 900 151 007 02 "washer B 7,4" 4 900 151 008 02 "washer A 8,4" 2 900 151 008 02 "washer A 8,4" 2 900 151 008 02 "washer B 8,4" 3 900 151 008 02 "washer B 8,4" 2 900 151 008 02 "washer A 8,4" 1 900 151 027 02 washer 90- 2 900 151 027 02 "washer B 5,3" 90- 2 900 151 027 02 "washer B5,3" 4 900 151 027 02 "washer A 5,3" 1 900 151 027 02 "washer A 5,3" 2 900 151 027 02 "washer A 5,3" 7 900 151 027 02 "washer B 5,3" 2 900 151 028 02 "washer B 4,3" 4 900 151 037 07 "washer 6,4" 4 900 151 037 07 "washer A 6,4" 4 900 151 037 07 "washer A 6,4" 2 900 155 036 02 "hexagon-head bolt M 10 X 50" 2 900 155 036 02 "hexagon-head bolt M 10 X 50" 1 900 159 008 02 grooved nut valve cover oil separator mounting nut 2 900 160 015 00 tab washer valve cover oil separator mounting tab washer 2 900 169 014 02 securing clip 1 900 169 014 02 securing clip 1 900 169 016 02 clip round ball socket retaining clip on hood shocks 4 900 169 016 02 clip rear hatch strut ball retaining clips 4 900 174 011 40 o-ring 1 900 174 032 40 "round seal 18 X 2,5" 4 900 174 044 40 "round seal 9 X 2" dipstick tube o-ring 1 900 174 044 40 round seal 1 900 174 056 40 "o-ring 17 X 2,5" valve cover breather elbow and plug o-ring 4 900 175 002 02 screw 1 900 180 031 50 hose carbon canister hose 1 900 187 004 02 "hexagon-head tapping screw 4,8 X 19" 4 900 187 010 02 "tapping screw BZ 6,3 X 19" 2 900 187 010 02 "tapping screw BZ 6,3 X 19" 2 900 187 013 02 "tapping screw 4,2 X 13" 2 900 187 015 02 "tapping screw 6,3 X 16" 2 900 187 018 02 "hexagon-head tapping screw B 4,8 X 16" 9 900 187 018 02 "hexagon-head tapping screw 4,8 X 16" 1 900 187 032 02 "tapping screw 6,3 X 32" 1 900 187 032 02 tapping screw 4 900 187 033 02 "tapping screw B 4,8 X 50" 1 900 187 104 02 "tapping screw B 4,8 X 13" 2 900 187 108 02 "tapping screw BZ 6,3 X 16" 4 900 187 108 02 "tapping screw BZ 6,3 X 16" 1 900 187 115 02 screw 900 187 115 02 "screw B 5,5 X 16" captive washer machine screw for splash shields 10 900 187 115 02 "screw B 5,5 X 16" 16 900 187 115 02 "screw B 5,5 X 16" 15 900 187 115 02 "screw B 3,5 X 16" 2 900 187 121 02 "tapping screw B 4,8 X 22" 3 900 190 005 03 "tubular rivet B 4 X 9 X 6" tubular rivet in cargo cover canvas at rear edge 2 900 197 018 00 "roll pin 4 X 12" 1 900 197 042 01 "roll pin 10 X 12" 2 900 197 042 01 "roll pin 10 X 12" 2 900 197 044 01 "tensioning sleeve 16 X 16" torque tube roll pins 2 900 219 001 30 screw plug 1 900 219 006 02 screw plug 2 900 223 003 02 "washer 6,4" 4 900 223 003 02 "washer 6,4" 1 900 223 011 02 "washer B 10,5" /LL 1 900 223 011 02 "washer B 10,5" 4 900 223 011 02 washer 10 900 234 003 02 "shim 8 X 14 X 1" TB crank gear idler mounting shim 2 900 234 041 01 "shim 10 X 16 X 1,3" 1 900 234 510 02 "support washer S 10 X 16" 2 900 249 001 02 "countersunk-head screw M 6 X 15" 2 900 249 008 02 "countersunk-head screw 6 X 12" 1 900 249 008 02 "countersunk-head screw M 6 X 12" 1 900 249 008 02 2 900 249 008 02 "countersunk-head screw M 6 X 12" 4 900 249 023 00 "countersunk-head screw M 6 X 10" 2 900 249 024 00 "countersunk-head screw M 8 X 25" 4 900 265 001 50 rubber valve 4 900 269 006 07 "countersunk-head screw M 4 X 8" 2 900 269 015 02 "countersunk-head screw M 5 X 10" 6 900 269 050 07 "countersunk-head screw M 5 X 25" 8 900 269 052 07 "countersunk-head screw M 4 X 10" 6 900 272 003 02 hose clamp 2 900 273 003 01 "circlip 22 X 1,2" 1 900 278 002 02 "hexagon-head bolt CM 6 X 16" -90 3 900 281 002 40 hexagon nut headlight washer nozzle mounting nuts 2 900 309 010 00 "roll pin 3 X 32" rear console package box hinge pin 2 900 309 013 00 roll pin 1 900 309 035 00 "roll pin 5 X 40" -89 1 900 309 035 00 "roll pin 5 X 40" 3 900 312 012 02 plug metal stopper plug for vacuum distributor 1 900 317 001 00 needle-roller bearing clutch pedal chaft roller bearings 2 900 331 022 40 o-ring 90-95 engine oil cooler o-rings 2 900 331 022 40 o-ring 90-95 engine oil cooler o-rings 2 900 336 001 02 "washer 4" 8 900 906 002 00 circlip TB tensioner piston base / valve support circlip 1 900 906 046 00 outer ring circlip for filler neck surround 1 900 910 003 02 "lock nut VM 8" 2 900 910 006 02 "lock nut M 4" 4 900 910 009 02 "lock nut M 5" 8 900 910 009 02 "lock nut M 5" 4 900 910 009 02 "lock nut M 5" 4 900 910 009 02 "lock nut M5" 4 900 910 010 02 lock nut 2 900 910 010 02 lock nut 2 900 910 010 02 lock nut 5 900 910 010 09 "lock nut M 6" X 900 910 010 09 "lock nut M 6" 1 900 910 010 09 "lock nut VM 6" 1 900 910 012 02 lock nut 1 900 910 012 02 "lock nut M 6" 6 900 910 012 02 "lock nut M 6" 4 900 910 012 02 "lock nut M 6" 90- 4 900 910 012 02 "lock nut M 6" 4 900 910 022 02 lock nut 10 900 910 022 02 "lock nut M 8" 4 900 910 022 02 lock nut 4 900 910 022 02 lock nut X 900 910 022 02 lock nut 3 900 910 022 02 lock nut 2 900 910 022 02 "lock nut M 8" 1 900 910 022 09 "lock nut M 8" 4 900 910 031 09 "lock nut NM 10" 6 900 910 031 09 lock nut 4 900 910 031 09 lock nut 6 900 910 031 09 lock nut 2 900 910 031 09 "lock nut VM 10" 2 900 910 046 02 "lock nut M 12 X 1,5" 4 900 910 046 02 lock nut 2 900 910 046 02 lock nut 2 900 910 093 02 lock nut rear axle nut 2 900 910 094 02 lock nut 2 900 910 094 02 lock nut 4 900 910 095 02 "lock nut M 8" 2 900 910 096 02 "lock nut M 6" 10 900 910 115 02 lock nut 4 900 910 118 00 "lock nut M 6" 4 900 915 003 02 screw socket oil cooler hose threaded inserts to block 2 999 012 034 00 "straight pin 8 M 6 X 12" cylinder head to deck roll pins 4 999 014 013 02 pan-head screw 4 999 015 004 02 "screw AM 5 X 10" 4 999 015 005 07 half-round screw ball socket for rear hatch shock? 4 999 021 003 00 lock 1 999 021 005 01 cotter pin 1 999 025 068 07 "washer 9 X 25 X 3,5" TB tensioner roller bolt thick washer 1 999 025 074 02 washer front shock lower bolt large washer 2 999 025 075 02 "washer 8,5 X 19 X 6" air pump tensioner thick spacer washer 1 999 025 075 02 "washer 8,5 X 19 X 6" 1 999 025 078 02 "washer 8,4 X 17 X 1,5" 2 999 025 078 02 washer 2 999 025 078 02 washer 2 999 025 083 70 "washer 3,7 X 11 X 0,5" 10 999 025 086 02 "square washer 12,1 X 24" transmission mounting square washer 2 999 025 086 02 "square washer 12,1 X 24" 2 999 025 091 02 washer 4 999 025 093 09 "washer 6,4" 4 999 025 108 02 "washer 6,4" 4 999 025 108 02 "washer 6,5" 4 999 025 202 02 washer 1 999 025 208 40 "washer 15,1 X 26 X 1,2" 1 999 028 014 02 "spring washer F 92KS8 60873>>" 2 999 034 007 02 "hexagon flat nut M 12 X 1" flat mounting nut for HVAC head blower switch 1 999 034 013 02 hexagon nut 2 999 041 021 01 "circlip 20 X 1,2" 1 999 042 017 01 snap ring 1 999 042 031 01 "snap ring 35 X 1,5" 1 999 049 008 40 plastic nut 90- 1 999 049 022 40 plastic nut plastic M6 front wheelwell liner nut 2 999 062 009 02 "stud M 8 X 28" 91- 4 999 062 044 02 "stud BM 8 X 30" exhaust manifold studs 16 999 063 002 40 "screw plug AM 12 X 1,5" 1 999 063 008 02 screw plug 2 999 064 030 30 "screw plug CM 38 X 1,5" rear cylinder head coolant plug 2 999 070 012 02 "cap nut M 14 X 1" 1 999 072 005 09 "hexagon-head bolt M 6 X 12" 2 999 072 005 09 hexagon-head bolt 88+ throttle cable wheel bracket 1 999 072 005 09 "hexagon-head bolt M 6 X 12" 1 999 072 005 09 "hexagon-head bolt M 6 X 12" 2 999 072 005 09 "hexagon-head bolt M 6 X 12" 2 999 072 005 09 "hexagon-head bolt M 6 X 12" 3 999 072 005 09 "hexagon-head bolt M 6 X 12" 3 999 072 005 09 "hexagon-head bolt M 6 X 12" 6 999 072 005 09 "hexagon-head bolt M 6 X 12" 2 999 072 005 09 "hexagon-head bolt M 6 X 12" 10 999 072 005 09 "hexagon-head bolt M 6 X 12" 2 999 072 005 09 "hexagon-head bolt M 6 X 12" 3 999 072 005 09 "hexagon-head bolt M 6 X 12" -90 1 999 073 030 02 "pan-head screw M 6 X 19" 2 999 074 043 02 "hexagon-head bolt M 6 X 65" 1 999 075 032 02 "hexagon-head bolt M 8 X 20" 4 999 076 032 02 "hexagon nut M 14 X 1" 1 999 084 047 02 "lock nut M 10" 2 999 084 052 02 "lock nut M 8" exhaust manifold M8 locknut 22 999 084 052 02 lock nut 2 999 084 052 02 lock nut 6 999 084 055 02 "lock nut M 8" 1 999 084 425 02 "lock nut M 8" 2 999 084 613 02 "lock nut M 6" 2 999 088 009 07 bolt 2 999 093 004 02 hexagon-head bolt 6 999 095 103 01 roll pin upper timing belt cover roll pin 2 999 119 001 01 "pan-head screw M 7 X 18" front wheel clamp nut socket head cap screw 2 999 134 027 02 "banjo bolt M 10 X 1" 2 999 134 039 02 banjo bolt X 999 137 054 40 y-piece windshield washer hose y-pipe 4 999 137 058 40 reducing socket 1 999 141 010 07 "countersunk-head screw 7 X 7" 14 999 143 003 02 "hexagon-head bolt M 5 X 10" 6 999 152 068 01 snap ring release bearing snap ring 1 999 152 084 01 circlip rear axle external snapring 2 999 152 089 01 snap ring 1 999 166 005 02 sl-lock 1 999 166 034 02 sl-lock /LL 1 999 166 034 02 sl-lock 1 999 166 040 02 kl-lock 1 999 166 046 02 lock accelerator cable C-clip at throttle quadrant 2 999 166 048 02 "bolt A 6 X 17 X 14" 1 999 166 050 02 bolt 1 999 166 054 02 sl-lock 4 999 166 071 01 support 1 999 167 033 00 ball pin -90 1 999 168 021 40 ball socket cooling flamp motor ball socket 2 999 217 006 07 "hexagon-head bolt M 6 X 10" 4 999 217 008 02 "hexagon-head bolt M 5 X 10" 4 999 217 017 02 "hexagon-head bolt M 8 X 18" 4 999 217 078 07 "hexagon-head bolt M 4 X 6" 2 999 217 079 07 "hexagon-head bolt M 6 X 12" 4 999 217 082 02 "hexagon-head bolt M 8 X 30" 2 999 217 164 02 "hexagon-head bolt M 6 X 15" 91- 3 999 218 005 02 "pan-head screw M 6 X 16" 1 999 218 010 02 "oval-head screw M 5 X 12" 2 999 218 016 02 "screw M 6 X 16" 2 999 218 019 02 "screw M 5 X 45" -90 2 999 218 023 02 "screw M 8 X 35" cam cap XZN bolt 52 999 218 035 02 threaded pin cylinder head oil pressure relief pin 1 999 218 073 02 "pan-head screw M 5 X 45" 91 2 999 219 003 07 "countersunk-head screw M 6 X 16" 2 999 223 002 02 "stud M 8 X 40" intake manifold studs in cylinder head 10 999 230 106 02 nipple 1 999 230 158 02 nipple banjo fitting to suction side of power steering pump- elastic ? 1 999 230 366 40 elbow 1 999 234 004 00 shim 1 999 234 024 00 thrust washer 4 999 235 002 90 "sealing ring 24 X 33 X 8" 1 999 450 001 07 "round head screw B 4,2 X 25" 4 999 450 004 02 "tapping screw B 4,2 X 28" 4 999 450 005 02 "tapping screw B 4,2 X 32" 6 999 450 007 02 screw 24 999 460 002 02 eye screw air pump belt tensioner eye bolt 1 999 460 002 02 eye screw 1 999 460 003 02 eye screw AC compressor tensioner eye bolt 1 999 507 002 02 speed nut 2 999 507 002 02 speed nut 2 999 507 002 02 speed nut 2 999 507 003 02 speed nut 1 999 507 003 02 "speed nut B 6,3" 1 999 507 003 02 speed nut 26 999 507 003 02 "speed nut B 6,3" 2 999 507 003 02 "speed nut B 6,3 X 16" 1 999 507 020 02 "speed nut 4,2" 1 999 507 029 02 speed nut 2 999 507 030 02 "speed nut 4,8" 3 999 507 034 02 "speed nut B 6,3" CE panel upper mounting speed nut 2 999 507 037 02 "speed nut 4,2" 2 999 507 048 03 "speed nut M 6" 2 999 507 050 40 expander nut 91- 1 999 507 229 02 "speed nut B 4,2" 2 999 507 243 02 kronen-fix 6 999 507 244 02 kronen-fix 1 999 507 245 02 speed nut 1 999 507 245 02 speed nut 1 999 507 246 02 "speed nut M 6" 1 999 507 247 02 mecano-speed-fix press on retaining clip for mounting vacuum pods 6 999 507 248 02 "speed nut M 5" 2 999 507 248 02 "speed nut M 5" 1 999 507 248 02 speed nut 2 999 507 251 02 "mecano-speed-fix $ 5 MM" 7 999 507 326 02 "captive nut M 6" 2 999 507 330 02 nut lock cooling flamp frame nut lock X 999 507 330 02 "nut lock M 5" 4 999 507 348 02 "speed nut B 4,8" 4 999 510 029 02 "screw M 8 X 40" 18 999 511 066 02 clamp 2 999 511 066 02 clamp 1 999 511 076 02 "clamp B 20 X 18" 1 999 511 085 02 clamp 1 999 511 116 02 clamp 1 999 511 116 02 clamp 1 999 511 118 02 clip 1 999 511 121 40 clip -90 power steering line mounting block 1 999 511 138 02 clip Front body wiring harness pipe clamp- perhaps mounts in body holes? 1 999 511 142 02 "clamp 17 X 15" 1 999 511 156 00 clamp 2 999 511 156 00 "clamp 13/15 W 5" battery positive cable mounting clamps 13 999 511 171 02 clip 1 999 511 191 02 "clip 8 / 12" 88- 1 999 512 038 02 hose clamp 1 999 512 038 02 hose clamp 1 999 512 044 02 hose clamp 1 999 512 044 02 hose clamp 1 999 512 055 02 hose clamp 2 999 512 160 02 "hose clamp S 13/9" 2 999 512 160 02 "hose clamp S 13/9" 2 999 512 237 02 hose clamp 4 999 512 237 02 hose clamp 4 999 512 272 02 hose clamp 2 999 512 276 02 clip fuel filter hose clamp mount 1 999 512 325 02 clip torque tube to resonator exhaust pipe mounting clamp 1 999 512 329 02 clip air pump diverter valve mounting bracket clamp at exhaust manifold 1 999 512 331 02 "hose clamp S 61/15" 1 999 512 334 02 "hose clamp S 59/15" 1 999 512 344 02 "clamp 49,9 - 53,0" TB tensioner boot Oetiker clamp 1 999 512 346 00 "hose clamp A 20/9" 1 999 512 346 00 hose clamp 1 999 512 346 00 hose clamp 6 999 512 346 02 hose clamp 2 999 512 346 02 hose clamp 4 999 512 350 02 hose clamp hose clamp for lower plenum elbow 2 999 512 350 02 "hose clamp SGL 80-100-9" power steering reservoir mounting bracket 1 999 512 355 02 hose clamp 2 999 512 358 02 hose clamp 1 999 512 358 02 hose clamp 1 999 512 374 02 "hose clamp SGT 20 - 32/9" 3 999 512 374 02 hose clamp 4 999 512 381 02 clamp 1 999 512 381 02 clamp 1 999 512 394 00 hose clamp fuel pump hose clamp mount 1 999 512 404 00 "hose clamp 50 - 70 W2" 2 999 512 456 00 clamp brake vacuum hose from venturi to check valve 1 999 512 457 00 clamp 1 999 512 457 00 clamp 2 999 512 489 00 hose clamp 6 999 512 497 02 clamp 1 999 512 532 00 terminal 3 999 512 552 00 hose clamp 1 999 512 552 00 hose clamp 1 999 512 554 00 hose clamp 3 999 512 554 00 hose clamp 1 999 512 554 00 "hose clamp A 18/9" -88 1 999 512 554 00 "hose clamp A 18/9" 2 999 512 554 00 hose clamp 2 999 512 554 00 hose clamp 4 999 512 554 00 "hose clamp A 8 X 9" 3 999 512 554 00 hose clamp 1 999 512 555 00 "terminal 9,8 - 12,3" 1 999 513 001 40 tie-wrap 1 999 513 002 40 "tie-wrap 286 MM" dash harness tie wrap 1 999 513 003 40 tie-wrap 4 999 513 003 40 tie-wrap tie wrap for battery to starter cable 1 999 513 007 40 tie-wrap 1 999 513 007 40 "tie-wrap 88 MM" "tie-wrap 88 MM" 8 999 513 007 40 "tie-wrap 80 MM" dash harness tie wrap 8 999 513 010 40 tie-wrap 1 999 513 021 40 tie-wrap 1 999 513 023 40 "tie-wrap 120 MM" "tie-wrap 120 MM" 13 999 513 023 40 "tie-wrap 160 MM" "tie-wrap 160 MM" 2 999 513 023 40 "tie-wrap 293 MM" dash harness tie wrap 1 999 521 037 01 compression spring 1 999 523 102 02 lock washer 7 999 523 102 02 lock washer 1 999 523 102 02 lock washer 4 999 523 102 02 "lock washer 8" knurled lock washer rings for door mounting SHCS 12 999 523 104 02 "lock washer 6 PN" 2 999 531 014 02 bush 3 999 571 045 02 rim wrench 78-95 1 999 591 102 07 protection washer 5 999 591 242 01 "speed nut D = 4,0" 2 999 591 348 02 "speed nut B 4,8" 9 999 591 349 02 speed nut 999 591 349 02 speed nut 4 999 591 377 02 speed nut 3 999 591 380 02 cable clamp dash harness cable clamp 5 999 591 380 02 cable clamp 5 999 591 423 03 tapping nut hood emblem mounting speed nut 2 999 591 425 03 mecano-speed-fix 1 999 591 434 02 "spring blower switch" metal flat spring for shaft opening, HVAC head blower switch 1 999 591 437 07 "washer 4,8" 4 999 591 437 07 "washer 4,8" 2 999 591 440 02 "clamp 0,75 - 1,0" 3 999 591 448 02 fixing clip rear end of sunroof guide rail mounting clip 1 999 591 451 40 clamp white plastic door sill mounting clips 12 999 591 459 02 mecano-speed-fix 2 999 591 465 02 cable clamp 2 999 591 483 40 lock washer lock washer for backing tool tray plastic **** 2 999 591 484 02 clamping washer clamping washer holding quarter panel receptacle to quarter panel 4 999 591 485 02 "speed nut B 4,8" 5 999 591 487 02 speed nut 1 999 591 487 02 "speed nut B 5,5" 16 999 591 487 02 "speed nut B 5,5" 15 999 591 487 02 "speed nut B 5,5" 2 999 591 498 40 special nut 4 999 591 498 40 special nut 4 999 591 519 40 expansion rivet rear edge of door sill plastic expansion rivet 2 999 591 539 07 clamp stainless staples for bumper cover sealing strips X 999 591 539 07 clamp stainless staples for bumper cover sealing strips X 999 591 559 40 clip headliner mounting clips for use with sunroof 10 999 591 559 40 clip mounting clips for rear upper headliner 8 999 591 564 40 "expansion rivet black" plastic expansion rivets for lower rear hatch lining 8 999 591 570 40 clip 2 999 591 571 02 "speed nut B 6,3" 2 999 591 583 02 speed nut 16 999 591 590 02 speed nut push-on speed nuts for firewall retaining strip 7 999 591 699 02 "speed nut B 4,8" 4 999 591 699 02 "speed nut B 4,8" -89 3 999 591 699 02 "speed nut B 4,8" -89 3 999 591 699 02 "speed nut B 4,8" -89 2 999 591 699 02 "speed nut B 4,8" 4 999 591 699 02 "speed nut B 4,8" 6 999 591 716 02 "tapping nut 3,0" 4 999 591 717 40 "expander nut B 4,2" 12 999 591 736 02 speed nut press-on speed nuts for battery box heat shield 10 999 591 736 02 speed nut 90- 8 999 591 749 02 clamp mounting clips for A-pillar covers 4 999 591 751 02 B3.9 speed nut 999 591 760 02 clamp mounting clips for door upper frame linings 14 999 591 779 40 "expander nut B 4,8" 2 999 591 787 09 "speed nut B 4,2 F >>92HS8 40080 F >>92HS8 49560 F >>92HS8 60065" 2 999 591 787 09 "speed nut B 4,2 F >>92HS8 40080 F >>92HS8 49560 F >>92HS8 60065" 2 999 591 796 02 clamp 4 999 591 797 02 "speed nut B 4,2" 10 999 591 839 40 hexagon nut plastic hex nut for spare tire well L-cover. Also used on front wheelwell plastic splash shields (?) 1 999 591 839 40 "hexagon nut T 5" battery positive cable hex nuts 13 999 591 861 02 "clamp for front spoiler" bottom of front bumper cover metal clips for mounting front spoiler 6 999 591 862 02 desk pad gasket for front bumper cover metal clips for mounting front spoiler 6 999 591 863 40 clamp 1 999 591 863 40 clamp 1 999 591 864 40 rubber mounting 1 999 591 873 02 "speed nut B 4,2" 2 999 591 882 02 "speed nut M 6" 2 999 591 898 02 clamp -90 sunroof outerpanel clamps 18 999 591 898 02 clamp 91+ sunroof outer panel clamps 18 999 591 930 40 support 1 999 591 938 02 "clamp B 4,8" -90 2 999 591 957 40 "fastening screw cover control units" LH-EZK brain cover plastic screw, 89+ 1 999 591 981 02 retaining clip white plastic retaining loop for cooling flap motor multipin connector housing (?) 2 999 919 008 07 "oval-head screw 3,9 X 13" 2 999 919 008 07 "oval-head screw 3,9 X 13" 4 999 919 008 07 "oval-head screw 3,9 X 13" 2 999 919 010 02 "oval-head sheetmetal screw B 4,2 X 9,5" 3 999 919 030 02 screw -89 8 999 919 030 02 screw 19 999 919 035 02 hexagon-head bolt 4 999 919 067 02 "countersunk-head screw KA 3 X 10" 4 999 919 084 07 "tapping screw B 4,2 X 22" 89- 4 999 919 100 02 "screw 4,0 X 10" 8 999 920 004 02 u-clamp 10 999 920 005 02 u-clamp 4 999 924 001 40 bush 2 999 924 001 40 bush 1 999 924 002 40 plain bearing 1 999 924 002 40 plain bearing shifter lever plastic bearings 4 999 924 002 40 plain bearing /LL 1 999 924 002 40 plain bearing gas pedal pivot lever plastic bushing 2 999 924 061 02 bush driver's side knee bolster mounting stud spacer 1 999 924 082 02 bush 90 1 999 924 082 02 bush 1 9WW cobalt blue E 477 298 843 circlip AC compressor coil mounting circlip 1 E 900 085 003 02 "cap nut M 6" 2 E 900 089 015 07 washer 2 E 900 115 004 01 "serrated lock washer 8,4" 2 E 900 119 024 02 "pan-head screw M 4 X 12" 1 E 900 143 066 07 "tapping screw 7 X 7" 3 E 900 198 001 02 "square nut M 5" 2 E 901 564 663 05 cap 1 E 999 025 085 02 "washer 12,5 X 30 X 1" X E 999 058 001 00 "knurled screw M 6 X 10" amplifier cover mounting knurled screws 2 E 999 084 045 02 lock nut -90 1 E 999 509 012 02 "pan-head screw M 6 X 20" 8 E 999 591 368 02 "speed nut 4,2" 2 E 999 591 865 02 nut 90- 2 E 999 651 158 02 "cable holder pulse sender" metal arm for holding speedometer pickup - NLA 1 E 999 651 158 02 cable holder pulse sender cable holder 1 E 999 651 158 02 cable holder -90 1 E 999 659 002 50 protective cap water protection cap over door edge illumination lamp 2 E N 012 410 1 "circlip 10 X 1" 1 E N 013 892 4 tapping screw 1 G2X "prime coated for towing lug" GRV prime coated GRV prime coated GRV prime coated GRV prime coated GRV prime coated GRV prime coated N 010 141 4 "hexagon-head bolt M 12 X 1,5 X 45" 2 N 010 142 2 "hexagon-head bolt M 12 X 1,5 X 50" 2 N 010 142 2 "hexagon-head bolt M 12 X 1,5 X 50" 2 N 010 142 2 "hexagon-head bolt M 12 X 1,5 X 50" 2 N 010 142 6 "hexagon-head bolt M 12 X 1,5 X 50" 4 N 010 154 3 "hexagon-head bolt M 12 X 1,5 X 55" 2 N 010 156 3 "hexagon-head bolt M 12 X 1,5 X 70" 2 N 010 156 3 "hexagon-head bolt M 12 X 1,5 X 70" 1 N 010 165 3 "hexagon-head bolt M 12 X 1,5 X 65" 2 N 010 183 3 "hexagon-head bolt M 12 X 1,5 X 75" 2 N 010 205 6 "hexagon-head bolt M 5 X 10" 1 N 010 205 6 "hexagon-head bolt M 5 X 10" 2 N 010 205 6 "hexagon-head bolt M 5 X 10" 4 N 010 207 6 "hexagon-head bolt M 5 X 12" 3 N 010 207 6 "hexagon-head bolt M5 X 12" 4 N 010 207 6 "hexagon-head bolt M 5 X 12" 2 N 010 210 13 "hexagon-head bolt M 6 X 10" 8 N 010 210 7 "hexagon-head bolt M 6 X 10" 2 N 010 210 7 "hexagon-head bolt M 6 X 10" 1 N 010 212 4 "hexagon-head bolt M 6 X 12" 1 N 010 215 13 hexagon-head bolt -90 3 N 010 215 13 "hexagon-head bolt M 6 X 15" 2 N 010 217 9 "hexagon-head bolt M 6 X 20" 2 N 010 217 9 "hexagon-head bolt M 6 X 20" 5 N 010 217 9 "hexagon-head bolt M 6 X 20" 4 N 010 217 9 "hexagon-head bolt M 6 X 20" 4 N 010 217 9 "hexagon-head bolt M 6 X 20" 1 N 010 219 2 "hexagon-head bolt M 6 X 28" 3 N 010 221 3 "hexagon-head bolt M 6 X 35" 2 N 010 221 3 "hexagon-head bolt M 6 X 35" 1 N 010 225 4 "hexagon-head bolt M 5 X 8" 2 N 010 227 2 "hexagon-head bolt M 6 X 18" 4 N 010 227 2 "hexagon-head bolt M 7 X 12" 8 N 010 233 6 "hexagon-head bolt M 8 X 28" 2 N 010 233 6 "hexagon-head bolt M 8 X 28" 1 N 010 233 6 "hexagon-head bolt M 8 X 28" 90- 1 N 010 237 6 "hexagon-head bolt M 8 X 12" 1 N 010 237 6 "hexagon-head bolt M 8 X 12" 2 N 010 237 6 "hexagon-head bolt M 8 X 12" 6 N 010 239 11 "hexagon-head bolt M 8 X 18" 2 N 010 239 11 "hexagon-head bolt M 8 X 18" 2 N 010 242 12 "hexagon-head bolt M 8 X 25" 3 N 010 244 6 "hexagon-head bolt M 8 X 30" 7 N 010 246 4 "hexagon-head bolt M 8 X 45" X N 010 248 1 "hexagon-head bolt M 8 X 60" 1 N 010 253 7 "hexagon-head bolt M 10 X 22" 4 N 010 275 3 "hexagon-head bolt M 10 X 35" /LL 1 N 010 335 5 "hexagon-head bolt M 8 X 35" 4 N 010 335 5 "hexagon-head bolt M 8 X 35" 1 N 010 340 4 "hexagon-head bolt M 8 X 40" 2 N 010 340 6 "hexagon-head bolt M 8 X 40" 1 N 010 340 6 "hexagon-head bolt M 8 X 40" 1 N 010 340 6 "hexagon-head bolt M 8 X 40" 4 N 010 340 6 "hexagon-head bolt M 8 X 40" 4 N 010 349 5 "hexagon-head bolt M 6 X 45" 2 N 010 353 3 "hexagon-head bolt M 8 X 42" 4 N 010 353 3 "hexagon-head bolt M 8 X 42" 3 N 010 359 4 "hexagon-head bolt M 8 X 40" 2 N 010 359 4 hexagon-head bolt 3 N 010 359 4 "hexagon-head bolt M 8 X 38" 1 N 010 360 6 "hexagon-head bolt M 8 X 60" 1 N 010 361 4 "hexagon-head bolt M 8 X 65" M8 girdle bolts 10 N 010 361 4 "hexagon-head bolt M 8 X 65" 1 N 010 366 4 "hexagon-head bolt M 6 X 55" 1 N 010 367 4 "hexagon-head bolt M 6 X 60" 4 N 010 445 2 "hexagon-head bolt M 10 X 45" 8 N 010 445 2 "hexagon-head bolt BM 10 X 45" 4 N 010 445 2 "hexagon-head bolt M 10 X 45" /LL 4 N 010 445 2 "hexagon-head bolt M 10 X 45" 2 N 010 450 5 "hexagon-head bolt M 10 X 50" 4 N 010 455 3 "screw M 10 X 55" cam gear mounting bolt 2 N 010 455 3 "screw M 10 X 55" 2 N 010 470 7 "hexagon-head bolt M 10 X 70" 2 N 010 472 4 "hexagon-head bolt M 10 X 85" 2 N 010 473 6 "hexagon-head bolt M 10 X 75" 4 N 010 473 6 "hexagon-head bolt M 10 X 75" 6 N 010 482 3 "hexagon-head bolt M 10 X 105" 4 N 010 482 3 "hexagon-head bolt M 10 X 105" 2 N 011 004 6 "hexagon nut M 4" -90 2 N 011 004 6 "hexagon nut M 4" 1 N 011 004 6 "hexagon nut M 4" -88 16 N 011 004 6 "hexagon nut M 4" 4 N 011 005 14 "hexagon nut M 5" 2 N 011 005 14 "hexagon nut M 5" 1 N 011 005 14 "hexagon nut BM 5" 3 N 011 005 14 "hexagon nut M 5 see technical information GR. X NR. 15" 1 N 011 005 14 "hexagon nut M 5" 1 N 011 005 14 "hexagon nut M 5" 1 N 011 005 14 "hexagon nut M 5" 2 N 011 005 14 "hexagon nut M 5" 2 N 011 005 14 "hexagon nut M 5" 2 N 011 005 14 "hexagon nut M 5" 5 N 011 005 14 "hexagon nut M 5" 4 N 011 005 14 Hex nut M5 N 011 005 14 M5 hex nut N 011 005 14 "hexagon nut M 5" 6 N 011 005 14 "hexagon nut M 5" 1 N 011 005 14 hexagon nut 1 N 011 008 8 "hexagon nut M8" 1 N 011 010 13 "hexagon nut M 10" Girdle M10 nuts 22 N 011 010 6 "hexagon nut M 10" 1 N 011 010 6 "hexagon nut M 10" 1 N 011 010 6 "hexagon nut M 10" -89 1 N 011 018 4 "hexagon nut M 8 X 1" 1 N 011 020 8 hexagon nut 1 N 011 022 1 "hexagon nut M 16 X 1,5" 88- 1 N 011 121 1 "cap nut M 6" 90- 2 N 011 141 2 "cap nut M 5" 1 N 011 521 3 washer X N 011 521 3 "washer A 3,7" 90- 2 N 011 522 14 "washer 4,3" 2 N 011 522 15 washer -90 2 N 011 522 8 "washer A 4,3" 4 N 011 522 8 "washer A 4,3" 4 N 011 523 11 "washer A 5,3" 2 N 011 523 11 "washer A 5,3" 3 N 011 524 7 "washer A 6,4" 6 N 011 524 7 "washer A 6,4" 4 N 011 524 7 "washer A 6,4" 4 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" X N 011 524 7 "washer A 6,4" -90 3 N 011 524 7 washer 2 N 011 524 7 "washer A 6,4" 5 N 011 524 7 "washer B 6,4" 1 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 12 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 4 N 011 524 7 "washer A 6,4" 90- 4 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 1 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 4 N 011 524 7 washer 2 N 011 524 7 "washer A 6,4" 1 N 011 524 7 "washer A 6,4" 1 N 011 524 7 "washer B 6,4" 4 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" /LL 2 N 011 524 7 "washer A 6,4" 10 N 011 524 7 "washer A 6,4" 1 N 011 524 7 "washer A 6,4" -89 4 N 011 524 7 "washer A 6,4" 4 N 011 524 7 "washer A 6,4" 1 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 4 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 1 N 011 524 7 "washer 6,4" 1 N 011 524 7 "washer 6,4 X 14" 3 N 011 524 7 "washer 6,4" 3 N 011 524 7 "washer 6,4" 1 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer 6,4" 1 N 011 524 7 "washer A 6,4" 2 N 011 524 7 "washer 6,4" -90 1 N 011 524 7 "washer A 6,4" 2 N 011 525 13 "washer A 8,4" 1 N 011 525 13 "washer A 8,4" 2 N 011 525 13 "washer A 8,4" 2 N 011 525 13 "washer A 8,4" 6 N 011 525 13 "washer A 8,4" /LL 2 N 011 525 13 washer 1 N 011 525 13 washer 88- 2 N 011 531 14 "washer B 12" 2 N 011 531 14 "washer A 13" 8 N 011 542 2 "washer A 17" 88- 1 N 011 550 1 "washer B 6,5" X N 011 550 1 "washer B 6,5" 3 N 011 556 2 "washer A 5,3" 1 N 011 564 2 washer 4 N 011 612 3 "washer R 6,6" 2 N 011 655 2 "washer F 92KS8 60873>>" 2 N 011 663 3 B3.7 washer N 011 663 3 "washer B 3,7" 1 N 011 665 10 washer 7 N 011 665 11 "washer B 5,3" 2 N 011 665 3 "washer B 5,3" 4 N 011 665 3 "washer B 5,3" 1 N 011 665 3 "washer B 5,3" 12 N 011 665 3 "washer B 5,3" 8 N 011 665 3 "washer B 5,3" 4 N 011 665 3 "washer B 5,3" 4 N 011 665 3 "washer B 5,3" -89 3 N 011 665 3 "washer B 5,3" -89 3 N 011 665 3 "washer B 5,3" 2 N 011 665 3 "washer B 5,3" 4 N 011 665 3 "washer B 5,3" 2 N 011 665 3 "washer B 5,3" 12 N 011 665 3 "washer B 5,3" 2 N 011 665 3 Washer B 5.3 N 011 665 3 "washer B 5,3" 6 N 011 666 6 "washer B 6,4" 4 N 011 666 7 "washer A 6,4" X N 011 666 7 "washer B 6,4" 6 N 011 666 7 washer 4 N 011 666 7 "washer B 6,4" 9 N 011 666 7 "washer B 6,4" 4 N 011 666 7 "washer B 6,4" 3 N 011 666 7 "washer B 6,4" 2 N 011 666 7 "washer B 6,4" 3 N 011 666 7 "washer B 6,4" 4 N 011 666 7 "washer 6,4" X N 011 666 7 "washer B 6,4" 6 N 011 918 1 cover oil galley cover X N 012 005 3 "lock ring B 5" 1 N 012 005 3 "lock ring B 5" 2 N 012 005 3 "lock ring B 5" 2 N 012 005 3 "lock ring B 5" 2 N 012 005 3 "lock ring B 5" 2 N 012 005 3 lock ring 6 N 012 006 4 "lock ring B 6" 4 N 012 006 4 "lock ring B 6" 12 N 012 006 4 lock ring 1 N 012 006 4 "lock ring B 6" 4 N 012 006 4 "lock ring B" 4 N 012 006 4 "lock ring B 6" 4 N 012 006 4 "lock ring B 6" 4 N 012 006 4 "lock ring B 6" 3 N 012 006 4 "lock ring B 6" 4 N 012 006 4 "lock ring B 6,4" 1 N 012 006 4 "lock ring B 6" -89 6 N 012 006 4 "lock ring B 6" 4 N 012 006 4 "lock ring B 6" 1 N 012 006 4 "lock ring B 6" 1 N 012 007 02 "lock ring A 6" 1 N 012 007 2 "lock ring A 6" 1 N 012 009 3 "lock ring A" 4 N 012 009 3 "lock ring A 8" 1 N 012 016 1 lock ring alternator pulley mounting nut lock ring 1 N 012 026 3 "lock ring A 6" 8 N 012 222 4 "spring washer B 5" 2 N 012 224 3 "spring washer A 4" 2 N 012 225 3 "spring washer B 5" 8 N 012 226 5 "spring washer B 6" 2 N 012 226 5 "spring washer B 6" 4 N 012 226 5 "spring washer B 6" 6 N 012 226 5 "spring washer B 6" 2 N 012 226 5 "spring washer B 6" 2 N 012 226 5 spring washer 10 N 012 226 5 "spring washer A 6" 4 N 012 226 5 "spring washer A 6" 8 N 012 226 5 "spring washer B 6" 4 N 012 226 5 "spring washer B6" 2 N 012 226 5 "spring washer A 6" 4 N 012 226 5 "spring washer B 6" 4 N 012 226 5 "spring washer B 6" 2 N 012 229 3 spring washer 1 N 012 229 3 "spring washer A 8" 1 N 012 230 1 "washer B 10" X N 012 232 1 "spring washer B 12" 4 N 012 232 1 connecting line 2 N 012 238 1 "spring washer B 16" 1 N 012 239 1 "spring washer B 18" 1 N 012 241 8 "spring washer B 8" 4 N 012 241 8 "spring washer B 8" 6 N 012 241 8 "spring washer B 8" 3 N 012 241 8 "spring washer B 8" 1 N 012 241 8 "spring washer B 8" 2 N 012 241 8 "spring washer B 8" 1 N 012 277 1 snap ring 1 N 012 314 1 snap ring 1 N 012 408 2 "circlip 8 X 0,8" TB crank gear idler mounting circlip 2 N 012 408 2 "circlip 8 X 0,8" 1 N 012 420 1 "circlip 20 X 1,2" valve cover breather elbow snap ring 2 N 012 432 1 lock washer 4 N 012 439 2 lock 1 N 012 439 2 lock washer 1 N 012 644 1 lock 1 N 012 644 1 lock 2 N 012 645 2 lock 1 N 012 653 1 "lock B 9" 1 N 012 654 1 lock 1 N 012 713 1 "woodruff key 5 X 6,5" oil pump shaft woodruff gear 1 N 013 199 1 "straight pin 6 X 12" water pump roll pin 2 N 013 295 1 "tensioning sleeve 3 X 12" 1 N 013 295 1 tensioning sleeve 1 N 013 315 1 "roll pin 5 X 10" 1st main bearing roll pin 1 N 013 317 1 roll pin 3 N 013 373 1 straight pin -88 2 N 013 381 1 straight pin -88 2 N 013 806 2 "sealing ring A 10 X 14" 2 N 013 883 3 "tapping screw B 4,8 X 9,5" 1 N 013 932 1 "tapping screw B 2,9 X 6,5" 5 N 013 935 2 "tapping screw BZ 6,3 X 25" CE panel upper phillips head machine screw 2 N 013 953 2 "tapping screw B 2,9 X 9,5" 1 N 013 954 2 "oval-head sheetmetal screw B 2,9 X 13" 3 N 013 957 5 tapping screw X N 013 957 5 "tapping screw B 3,5 X 9,5" 1 N 013 965 9 "oval-head sheetmetal screw BZ 4,2 X 9,5" 4 N 013 968 7 "tapping screw B 4,8 X 13" 2 N 013 968 7 "tapping screw B 4,8 X 13" 4 N 013 968 7 "tapping screw B 4,8 X 13" 2 N 013 968 7 "tapping screw 4,8 X 13" 2 N 013 970 5 "tapping screw B 4,8 X 9,5" 1 N 013 970 5 "tapping screw B 4,8 X 9,5" -90 1 N 013 973 4 "tapping screw B 5,5 X 13" 1 N 014 000 2 "tapping screw B 4,8 X 19" 2 N 014 001 1 N 014 001 1 2 N 014 098 6 tapping screw hood contact swith mounting screws pan 4.8 x 16 2 N 014 098 6 "tapping screw 4,8 X 16" 4 N 014 098 6 "tapping screw 4,8 X 16" 2 N 014 121 6 "oval-head screw M 4 X 6" 2 N 014 128 13 "oval-head screw M 5 X 8" 1 N 014 128 13 "oval-head screw M 5 X 8" 3 N 014 133 8 oval-head screw screw for output final stage amp connector spring 1 N 014 133 8 "oval-head screw M 5 X 12" 3 N 014 133 8 "oval-head screw M 5 X 12" 3 N 014 133 8 "oval-head screw M 5 X 12" 2 N 014 138 7 "oval-head screw M 6 X 10" /LL 2 N 014 139 11 "oval-head screw M 6 X 12" 4 N 014 139 7 "oval-head screw M 6 X 20" 1 N 014 140 5 "oval-head screw M 6 X 25" 1 N 014 701 7 pan-head screw 1 N 014 707 2 "pan-head screw M 8 X 15" 1 N 014 715 3 pan-head screw 2 N 014 725 2 "pan-head screw M 8 X 25" 88- 1 N 014 726 1 "pan-head screw M 8 X 30" 1 N 014 740 2 "pan-head screw M 6 X 16" /V 2 N 014 743 2 "pan-head screw M 6 X 30" /H N 014 760 3 "pan-head screw M 5 X 12" 1 N 014 761 2 "pan-head screw M 6 X 12" 4 N 014 761 2 "pan-head screw M 6 X 12" 4 N 014 770 3 "pan-head screw M 8 X 15" 4 N 014 782 1 "pan-head screw M 6 X 25" 3 N 015 404 1 "washer 6,4" 2 N 015 429 2 "speed nut B 4,2" 6 N 015 429 2 speed nut 2 N 016 163 2 "screw plug M 22 X 1,5" screw plug for oil cooler passages in girdle 2 N 019 908 1 "pan-head screw M 6 X 100" 2 N 019 908 1 "pan-head screw M 6 X 100" 2 N 020 139 1 "hose 4 X 1" * N 020 601 1 clip 2 N 020 601 1 clip 1 N 020 626 2 "clamp B 15 X 16" 2 N 021 022 2 union nut 2 N 021 130 3 lock nut 4 N 021 130 3 lock nut 4 N 021 196 1 lock nut 90- 2 N 021 196 1 "lock nut M 5" 16 N 022 141 1 "lock nut M 12 X 1,5" 2 N 022 141 1 "lock nut NM 12 X 1,5" 4 N 022 141 4 lock nut 4 N 023 565 3 hose clamp 2 N 023 569 2 "hose clamp AR 16/9" 1 N 023 569 2 hose clamp X N 023 570 2 hose clamp 2 N 023 570 2 "hose clamp S 17/9" X N 023 570 2 hose clamp X N 023 570 2 hose clamp 1 N 023 577 2 hose clamp 1 N 027 416 1 "shim 0,5 MM" X N 029 703 1 "screw plug M 12 X 1,5" block drain plug 2 N 033 167 1 "countersunk-head screw M 6 X 12" 4 N 033 167 1 "countersunk-head screw M 6 X 12" 4 N 040 108 1 "hexagon-head bolt M 12 X 1,5 X 40" 2 N 040 222 2 "hexagon-head bolt M 8 X 32" 1 N 040 222 2 "hexagon-head bolt M 8 X 32" 1 N 040 281 1 "hexagon-head bolt M 10 X 45" 1 N 040 301 1 "hexagon-head bolt M 8 X 48" starter mounting bracket bolts 2 N 040 301 1 "hexagon-head bolt M 8 X 48" 3 N 040 307 1 "hexagon-head bolt M 6 X 73" 1 N 042 121 3 "shake-proof washer A 6,4" 2 N 042 122 2 shake-proof washer 2 N 042 364 1 "circlip 20 X 1,75" TB tensioner roller circlip 1 N 043 285 1 "roll pin 5 X 18" -89 1 N 043 811 1 "sealing ring C 38 X 44" 2 N 043 884 1 "tapping screw B 4,2 X 13" 2 N 043 890 1 "tapping screw B 4,2 X 9,5" 2 N 043 890 1 "tapping screw B 4,2 X 9,5" /LL 2 N 044 728 1 "pan-head screw M 5 X 20" 4 N 044 734 1 pan-head screw X N 044 734 1 "pan-head screw M 5 X 16" 8 N 100 067 01 "hexagon-head bolt M 8 X 22" 1 N 100 438 01 bolt 2 N 101 003 1 circlip 1 N 101 111 01 "hexagon-head bolt M 8 X 95" 4 N 101 111 01 "hexagon-head bolt M 8 X 95" 90- 1 N 900 385 01 lock nut 4 N 900 470 01 lock washer 1 N 900 488 01 speed nut small air duct to cooling flap frame speed nut X N 900 488 01 speed nut 2 N 902 076 01 "washer 6,4 X 17 X 1,6" 2 N 902 689 01 "speed nut B 4,2" 2 N 902 707 01 "washer 6,1 X 18 X 1,5" 1
Chuck Z (03-16-2023)
As I suffer from a bit of a plating fetish, here are some thoughts for whatever they are worth. Having personally gone through cleaning, using a vibratory tumbler to polish and plating at home or sending out, I appreciate what went into these. For those who feel compelled to snark about the asking price, remember that there are members here who have paid close to a grand for an alternator and are happy they did it. The appropriate price is what someone will pay and that is an unknown at this point.
1. DIN standard nuts, washers and bolts - these are available from a variety of sources - including Bel-Metric in yellow zinc. I know that is not Cadmium, but the price and availability of these would factor in to your sales strategy. I would think packets of 10 to 20 by diameter would be logical. F the length, you don't have the time.
2. Oversize and specialty washers are a different story, and I would offer those up by location on the vehicle.
3. Anybody who asks or expects you to put together a "kit" for their specific vehicle is asking way too much of you.
4. OE hose and radiator clamps - sell individually, particularly the large radiator hose clamps (which I will buy if you don't sell them all to Mark)
5. Brackets - identify and sell individually or in sets as appropriate. i.e. two shock tower brackets, throttle bracket and associated hardware.
6. You might want to bring stuff to Sharks in Columbus as over 60 owners will be there.
I have a pile of nuts, bolts and washers on my workbench that I have been meaning to sort for about two years. I know your pain.
The plater I used has a minimum charge of $300 for a quantity not to weigh over a certain amount (don't remember the number but, my stuff didn't meet that threshold). If I had taken one set of the cam cover bolts it would have cost the same as it did to do all of what I did.
Code:
Would it be feasible to sell some of it by the pound and let the buyer take his/her chances and sort it out? Or at least the more generic items like nuts, bolts, washers, screws, etc. IDK, just thinking out loud here.
That’s an impressive amount of hardware!
Maybe you could do an exchange program especially for the fasteners. Say somebody sends you a bag of various nuts, bolts, washers, clips etc. (already degreased) and then you just duplicate the items with your newly plated parts. If you don’t have an item then just send back their old one(s). Maybe charge .10-.35 cents ??? per item plus return shipping. Charge more if they want all their hardware back? This way you won’t have to worry about ‘packages’ or ‘part numbers’ or itemizing huge number of items. Basically a ‘Monkey See Monkey Do’ program.
