What or is there a difference between a G28/03 and a G28/07 gearbox?
Working towards restarting my gearbox project and bumped into a potential good deal. I have a G28/03 box and bumped into a cheap G28/07 box. Can anybody confirm the gears etc are interchangeable or what the difference is?
thx again!
thx again!
Archive Gatekeeper
The gear ratios are slightly different, as is the ring and pinion set. I don't know how much of the boxes are physically interchangeable. Sliders are the same, I think the shift forks and rods are the same.
![](https://webfiles.uci.edu/redwards/public/928%20R%26P%20and%20Gear%20information%202-11-13.jpg)
@Rob Edwards @Mark Anderson thanks for the feedback. I will look further I need a replacement for my ring and pinion since I broke it trying to get the massive bolt of the axl ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Your numbers seem to imply that a GTS G28.57 input shaft can be installed in a G28.55 box? I am guessing that it would need also a G28.57 bearing, since Erkka years ago suggested the G28.57 shaft is thicker... If that's the case, there is a massive money saving since the GTS pinion and crownwheel are about 40% of the cost of the G28.55 ...
Alex
Rob,
Alex
Alex
I ask because I have a 91 GT transmission with a broken fifth gear input shaft.
Kevin
Can somebody point me to the bearing I will need to retrofit the GTS input shaft?
Archive Gatekeeper
They're #22A on sheet 303-05 in PET, 999 201 402 00. FWIW they are included with a new GTS 5th gear.
![](https://webfiles.uci.edu/redwards/public/GTS%205th%20gear%20roller%20bearings%202-28-11.jpg)
If so, what do I need to modify to swap the GTS gearset into my 91?
I have to modify something, right? Pardon my ignorance.
Archive Gatekeeper
Yes, order a 92830290534 and you get the input shaft, the 5th gear that goes on the layshaft, the needle bearings, and a spankin' new synchro. What's in the box is below in the pic.
I have to confess that I have not done this conversion, so I don't know what else needs to be modified. Just looking at the part numbers of the bits in and around the mainshaft and layshaft between a G28-12/13/55 vs. G28.57, the needle bearings are different, but the input bearing, layshaft axle, and the layshaft gear cluster are all the same. I do have a bare GTS pinion shaft here, if you need measurements off any part of its nose.
![](https://webfiles.uci.edu/redwards/public/GTS%205th%20gear%20whats%20in%20the%20box%202-28-11.jpg)
I have to confess that I have not done this conversion, so I don't know what else needs to be modified. Just looking at the part numbers of the bits in and around the main shaft and layshaft between a G28-12/13/55 vs. G28.57, the needle bearings are different, but the input bearing, layshaft axle, and the layshaft gear cluster are all the same. I do have a bare GTS pinion shaft here, if you need measurements off any part of its nose.
I'll reach out when I get to the point I need that.
Kevin
I have a 1990 G28.55 with spalling on the Crownwheel teeth. Porsche wants £2500 for a new set, while the GTS equivalent is only £900, hence I am severely tempted. The G28.13 is even cheaper and would swap straight over, but then I lose the 2.72 rear end vs 2.64...
So what would I need to change to swap a GTS pinion and crownwheel into a GT box?
