85 Valve Cover HELP!
Team 928,
I am about to embark on a journey! I will be replacing the valve cover gaskets on my 85 928. As I read through the prior posts, a few questions come up.
First off, I fully understand about the bolts and those silly nut sert type things.
Main question is on the access needs. On the passenger side, there is what appears to be an egr pipe and sensor? The bracket is mounted to the cylinder head.... How can I remove for access?
The front engine eye hook on the passenger side.... Can't quite see how to remove.
What else should come off on driver and passenger side for easy access? I want to avoid damaging the gasket and having the spark plug seals fall off.
I know the tensioner pads should be replaced but... my understanding is that the 85 pads are NLA. The pad screws onto the top part. I have seen pics that show a protrusion that goes into the pad. Problem is... I cant seem to find the old style pads. Don't really want to replace the tensioners with the newer and oil lines. Any thoughts on this?
Any pics would be greatly appreciated!
Thank you,
Thank you,
Basic Sponsor
85/86 tensioner pads are NLA
Check them for chain wear - grooves.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Mrmerlin (02-26-2023)
Team 928,
Thank you,
Thank you,
Dave K
