Under Dash Tray Repair Tricks
So the small push-clips that hold the under-dash tray to the front brace have all fallen out and/or some of the plastic posts are broken short. What is the best way to affix the tray to the front brace?
I'm assuming you are referring to the small posts sticking of the lower edge of Item 24 and the associated clips Item 26? if that is the case, I had a similar issue. I drilled through the tray at the post locations where the post was missing and then dropped a short black button head bolt through the top and installed a small nut on the bottom the front lip of the trap Item 25 extends up enough in the front so that you cant see the top of the button head bolts and has a recess where the original clips sat on the bottom that allows the nut to recess and be invisible as well. I can try to get a couple pic to show the finished assembly in the next day or 2 if you would like.
davesly (02-01-2023)
