Hello! And first question..
David,
in YT video 6 I think the two sized bores are broken and you need an engine shop and the next piston size to repair the block.
Oversize piston is 300 €, doing two bores I don't know but putting all together and try it in the car ist so much work so you should do it in the first attempt right.
I think the pros here can you tell more.
