Porsche 928 No Longer Available (NLA) List
hwyengr (06-21-2023)
The Parts Whisperer
The Parts Whisperer
The nipple on the Behr radiator is now NLA. Great opportunity for somebody to 3D print them.
Kevin
Kevin
I guess we'll have to use a banjo bolt in its place and cap the return line at the reservoir to bleed the system.
Then again this is just another good reason to install a CSF rad in its place....
The blue drain plug could be adapted.
Drill a hole through the drain plug with the same inside diameter as the nipple. I think the nipple on the clutch master is close to the size of the radiator nipple. Epoxy it into the drilled out drain plug. Not pretty but functional?
I'll try this later today.
Just my 5c.
Kevin in Atlanta (10-09-2023)
Jim Doerr will have these available to buy in December.
I preordered one.
Kevin
