93 Manual Transaxle leaks
My recent GTS purchase has a couple of minor transaxle weeps/leaks. One is from the back up light switch and the other presumably is from the rear shaft seal and possibly O-ring.
Transaxle has about 22k miles. According to the history I got with the car the says there's been Amsoil synthetic 75w90 EP gear lube. in there since 2008.
Given the two leaks it is it possible that Amsoil gear lube is at fault. I have Mobil 1 75w90 LS on order.
I've read about Redline leaks. Could the same be said of Amsoil?
