928 Engine Stalls
928 Engine Stalls
Hi to all,
91 S4 automatic
I need some help with an intermittent engine stalling issue. I am experiencing a loss of power and engine shutoff primarily in elevated outside temperatures 90°F. Temperature gauge indicating 190°F or less. After abt 15 min the car will restart and run well for abt 45 min and then stall again. It appears some temperature sensitive component is shutting down the engine. Not sure if the shutdown is fuel, electrical or vacuum system. The car is stock with abt 110,000 miles and in good condition otherwise.
91 S4 automatic
When's the last time you checked cranking end play?
It shuts down very quickly, I watched the tack drop off to zero RPM in abt 10 sec, I was looking for erratic RPM indication but the shut down was smooth. The shutdowns have occurred mostly under power climbing moderate grades at 60 MPH or more. I have compiled an extensive history if that would help?
John
John
John
John
Here:
http://928intl.com/repair/Relay/laterelay.htm
Replace the relays in positions:
IV
V
XXV
XXVI
Get them from:
https://928srus.com/products/copy-of...452f7ab3&_ss=r
Get more than you need, a spare or two isnt a bad idea..these are common failure points for stalling...and like I said, can common be heat related.
Also replace fuse #38, is the fuse melted, the contacts black/arced? Is the fuse socket darkened?
And IMHO, its a good idea to replace all fuses at this age, they corrode and get hot, and drop voltage...etc.
Do the fuse and relays, report back.
Thanks!!!
The car is down at the local Porsche Shop and I will pass you information on. In May we cleaned all of the ignition contacts and connectors, changed out all fuel filters, and replaced the crank sensor.
John
John
