89 S4 ABS Pump Motor Test
I'm chasing the ABS light (comes on within 10' of motion). I've tested the sensor grounds, resistance + a/c voltage at the controller when rotating wheels by hand, replaced the three relays, cleaned the pump ground and 12v connection. I'm planning to buy a cheap scope to look at the sensor waveforms but I wanted to test the pump in the meantime. Thanks, Tom
