Injectors for LH 16V fuel rail adapters.
Does anyone know of a supplier that has suitable injectors to fit the LH 16V Euro fuel rail adapters. I am not exactly sure of the part number but I have read 24lb and this may be the part number 0280 150 947.
I may find them in Australia. There are these they look about right. I am not keen on refurbished unless I took them for a flow check. https://www.ebay.com.au/p/244600263
Now I dont have the rail adapters yet but they are available.
I am also trying to chase some form of regulator replacement x2. Aftermarket stuff not available.
I have tried the normal venders and there seems to be limited supply and others I cant get through to.
https://www.summitracing.com/parts/acc-150824 work great with Gregs injector adaptor kit on the Euros.
Administrator - "Tyson"
Were the 85/86 32V cars sold down under? Those injectors will also work the same. Key points are 24lb flow rate & high impedance.
Hi Yeah. All the variants were sold here. I have 8 working injectors in my car. A couple were flow tested low when I was just about getting the car running. Now I am trying to get it running nice I wanted to change to a more modern injector and all new. Only because I believe everything I read..it seems a good idea.
Considering I still need the adapters I may have found an option in Australia. Is there any reason these wont work. Can be purchased for around $200 AUD. Less in USD.
https://raceworks.com.au/fuel/access...-tail-adapter/
I have asked for new reg adapters, injector adapters and if I can get injectors and Bosch regs to match and advice as well. Via PM, through the web email and recently Mary. However I appreciate it is busy times. I am not particular about who I buy from. I like to try and stay loyal to sponsors and to anyone who develop something to give them a chance sell their product. I have bought plenty from Roger as well. Last time I was presented with an optional choice of the crank case breather plates I chose Gregs product over the Hans product for that reason. I hadn't heard about Hans at the time so stuck with what I knew. At the end of the day its mainly about postage to Australia and if I can get it all in one place that works. And I usually add to the list to make it worth while. Roger has the adapters and after market regs. This is why this thread started as now I find myself researching what works and out sourcing. Correct I can ring Greg. Dont forget its international. He is currently active on the sight now and surely seen this thread. How much effort do I need to put in. Maybe I have crossed him somewhere. I keep seeing these lovely products posted up but getting a hold of them is another story. Now I have said this probably no chance.
My latest find. Look pretty sweet. And you can get them with AN fittings. Clamp on stainless steel.
![](https://www.efihardware.com/images/10292/14mm-Injector-Oring-To-Hose-Tail-Adapter.jpg)
![](https://www.efihardware.com/images/10293/14mm-Injector-Oring-To-Hose-Tail-Adapter.jpg)
![](https://www.efihardware.com/images/10296/Injector-Adapter-4AN-with-Stainless-Steel-Retaining-Clamp.jpg)
