928 Forum 1978-1995
Sponsored by: 928 Specialists
1979 Starter motor testing
Old Jul 4, 2022 | 04:27 AM
Todd Gibbs's Avatar
Todd Gibbs
Default 1979 Starter motor testing
Morning Gents,
I know this has been covered a few times, well close but not the same.. and ive not managed to find the answer through older threads.
So, I want to bench test my starter motor. The problem is that it has 4 connections... 3 and I would be ok, but I don't know what to do with the 4th and don't want to fry it.
Can anyone label them for me in this picture please?
As always, thanks for any help
Todd.
Old Jul 4, 2022 | 10:04 AM
Todd Gibbs's Avatar
Todd Gibbs
Ok, so (with a fully charged battery!) ...connecting permanent 12v positive to connector '2' and ground to the case (which I believe is the same as connector '4'), then tapping 12v positive to '3' spins the starter... so I know it works.
I have no idea what connector '1' does...
Todd.
Old Jul 4, 2022 | 03:18 PM
Alan's Avatar
Alan
Electron Wrangler
OK so:
1 is (15a) output to boost the spark voltage - active while starter active
2 is (30) the battery connection
3 is (50) starter signal from ignition switch / ignition relay (depending on year)
4 is (31) the grounding lug for the solenoid to the starter case (starter is grounded by bolting it to the block)
15a will have battery power while the starter is engaged - it is switched by (50) just like the starter solenoid/relay
I think 15a should have been called 50a (or e.g. 50z) for better functional understanding - it is NOT ignition (15) related
Alan
Old Jul 4, 2022 | 04:43 PM
Todd Gibbs's Avatar
Todd Gibbs
Originally Posted by Alan
OK so:
Alan
thanks Alan, that helps massively. Seems like my starter is working correctly as well
Todd
