Brake pad warning light
I jumped mine at the connector that goes to warning brain....it turned the light off
(yes, i will add real connectors....i had nothing with me other than a piece of lamp cord and a hunting knife)
that looks like an area where a connection could get bad and cause lack of continuity even with good sensors
I wonder if in my case the resistance on the flex print at the back of my instrument cluster is compremised...giving too much resistance in the circuit towards the CWU..
That should normally do the trick....but in my case it doesn't even work when bridging pin 19 & 20 on the CWU.....
