Flat Plane Crank in a 928 V8...???
wrong thread
I'm not sure what advantage a 'cross plane' V8 would offer since each bank has less inherent balance than a 180° in-line 4. For several years Yamaha (who also 'invented' the 5 valve layout and licensed it to Ferrari who used it for some years) have used a 'cross plane' crank in their R1 (1000cc in-line 4). This is to enable better grip characteristics due to the uneven firing order that results. However the additional vibration caused by the 'cross plane' crank requires balancer shafts that a regular 180° 'flat plane' in-line 4 in otherwise equivalent bikes does not require. .
