Some trouble on the road.. (Texas)
I'm having something come up more than it used to..It used to be just..once every few months. Now it's happened 2x today.
Im currently in Houston. The car will want to stall touching the throttle off idle, and when this happens RPMs just fall, not like a bad CPS, but the engine 90% stops running right away..hufs 5 or 6 compression stroked..and then comes back, or dies. When it dies..to restart it I have to go WOT, and its just pig rich, fuel smoke and all..and it will stumble a few seconds, and then run ok, have never had a hiccup in cruise, just coming off idle, and a hard start if it dies. LH going out? |
have a sharktuner handy? sounds like a TPS to me?
Originally Posted by Tony
(Post 18034310)
But FML if I'm going to replace that by myself on the road.. |
is the MAF new or rebuilt? Check operation by disconnecting to see if it changes this behavior. A bad MAF will run at idle and at around 3k rpm fine but like crap everywhere else.
Doesn't sound exactly like your problem, but something easy to check.. One other thought, Temp 2 sensor? |
Originally Posted by Tom. M
(Post 18034325)
Doesn't sound exactly like your problem, but something easy to check.. TPS is new 2019 @Precision. |
Originally Posted by Speedtoys
(Post 18034338)
MAF is rebuilt, 2016 from Roger.
Originally Posted by jcorenman
(Post 18034403)
Jeff, this smells like MAF to me.
I -should- make it to DFW Friday, where I can visit the Church Of The Roger... |
+1 for possible TPS. That sounds like the behavior my car had - stall at idle when warm, no problem when cold or under power. TPS was defective initially, then installed wrong by a newbie (me), both times issue confirmed by Bosch Hammer, corrected by repositioning/rotating the switch. Could probably be a bunch of other things as well.
Have the LH computer been rebuilt?
if its firing then the CPS should be OK. whats the condition of the MAF connector have the 4 running relays been replaced? are the battery terminal tight? whats the running voltage at the hot post? NOTE you can test the relays in position just ID the location the put your finger on each one, you can feel them click when you turn the key to run or after cranking. NOTE kneel on the ground with the CE panel cover removed and crank with the left hand with right hand on the relay |
Originally Posted by Mrmerlin
(Post 18034939)
if its firing then the CPS should be OK. whats the condition of the MAF connector have the 4 running relays been replaced? are the battery terminal tight? whats the running voltage at the hot post? NOTE you can test the relays in position just ID the location the put your finger on each one, you can feel them click when you turn the key to run or after cranking. NOTE kneel on the ground with the CE panel cover removed and crank with the left hand with right hand on the relay Connector seemed fine last I saw it a year ago Relays..I believe so, will double check, but I absolutely will in DFW this weekend. Battery is solid and tight..cable has been replaced as well...and ground. I don't have a DVM handy here in Houston, will in DFW. |
Originally Posted by chart928s4
(Post 18034858)
This will IDLE fine, but bring it off idle, it will fall down and die, then seem VERY fuel rich when restarting. |
MAF, bad connection to temp sender, or bad damper./regulator.
In my experience the LH either works or it doesn't and the throttle switch can't dump that much fuel without a corresponding big airflow signal from MAF. |
I'm sure there are multiple ways for our cars to do what yours is doing but what fixed mine is new dampers and FPR. I don't know which one of them was the culprit but they all got switched out and now everything is humming. Not as it should, mind you, there's a ton of work that I'm sure is still needed, but this stumbling thing right off idle is gone. On my car, it was subtle, but every so often I could feel a little bit of a stumble while cruising. With the engine above 1k rpm it never outright died, but it would have at idle!
ETA: Or what @GregBBRD said. Good luck, you're headed in the right direction for some solid help and support. Cheers |
Originally Posted by GregBBRD
(Post 18035096)
In my experience the LH either works or it doesn't and the throttle switch can't dump that much fuel without a corresponding big airflow signal from MAF. Weird that maf only does this..at this coming off idle area. |
Originally Posted by Zirconocene
(Post 18035104)
ETA: Or what @GregBBRD said. Good luck, you're headed in the right direction for some solid help and support. Cheers Ill go sniff around the dampers/regulator while it cold too today. These are new as of..2018? |
