Clear Turn Lenses US Upgrade
928 Collector
I'm working on a write-up of procedure. Wasn't a big job, and I think it looks so much better without that black rubber strip.
I think the rubber thingie is a US-market item. Something to do with the US regulations for bumpers. My Euro and all the others I've seen here in South Africa have the clear piece fitted. It has a 928 part number.
928 Collector
The lenses can be got from Joakim Jansson <Joakim-Jansson@swipnet.se>. I'm working on some pics I took, writing up the procedure ... should have something by this evening.
Thank you so much for doing this. I know watercooler has also replaced that black piece. If you could provide the procedure and part numbers for the replacement pieces, we would all be very grateful. Thanks.
Hi Flott,
Those clear side pieces are part # 928 631 961 00, and are named "TRIM" They are a "Euro" part, however any dealer can order them in.
They are sold as a set. Both left and right sides (of the same fog light).
I don't remember how much they cost, but I think they were under $20 a side. They are installed by just screwing in the little SS screw just like the regular US inboard piece.
As I wrote before, to use these clear trim pieces the metal 5 mph impact bracket has to be removed. It is wrapped in behind the lens housing, so the housing must be removed to get it out. Once the lens housing is removed you just have to drill out the small rivet that is holding it to the bumper cover.
Now in my car, when the lenses were removed from the lens housings (attached to the car), the 3 mounting bolts were recessed into the plastic at the back of the housing. This made them impossible to get off with out removing the bumper cover. However Chuck Z wrote that he could get his housings off by simply unbolting them from inside the housing. If this is true for your car, it is a simple 15 min job.
Go out to your car and remove a fog light lens. Look into the housing and see if there are 3 bolts that can be removed to get the housing off. If they are there, then you are golden. If the housing bolts are recessed into the plastic in the housing like mine, than the cover has to come off.
Best regards,
Mike
Best regards,
Mike
928 Collector
Well, sounds as if Mike has already posted detailed instructions :-) Thanks Mike, saves me the trouble. I however did not need to remove my nose.
928 Collector
Thanks Maddox. I discovered that, with a small modification to the bumper cover, this is an easy job. http://members.rennlist.com/heinrich/clearturn.htm
Hi Flott,
No problem I just returned home from working out of town for quite a while.
Didn't mean to steal your thunder Heinrick, but I think Flott asked me before, but I forgot. Sorry Flott.
I've been thinking though. If you guys have no trouble getting your lens housings off, maybe I have a set of 951 housings??? One of my lights was 951 when I got the car. I ditched the lens because it had a different profile that the S4 bumper cover, and the S4 lens went in perfect. I just assumed the housings were 928. I will have to check their part #'s.
Oh well, if they come out with ease, it is a real nice "cheap" mod!
Eating crow,
Mike
Eating crow,
Mike
I just installed the clear euro trim and clear turn signals lenses on tonight. I used a 3/4 inch hole saw without the center guide bit. This allows you to cut thru the metal bracket around the two studs. Worked like a champ, just be careful. You cut the bracket but could always put them back on. The rivets would hold them in place. If you don't want to cut it you will need to remove the cover.
Good luck!
PS: I have used this 3/4 inch hole saw to remove 5 twisted off wheel lug nuts. I used a dowel where the center bit was as a depth guide.
Good luck!
