Hard anodizing 928 calipers
Duplicolor makes a high temp caliper paint kit in various colors. Bought mine at Advanced Auto $15. Also comes with the degreaser. Bought red for the calipers and will get black for the rotors. You brush it on so overspray is not a problem.
I did this job on my Audi A4 last summer...used Duplicolor Hi-temp ceramic paint, along with good prep of wire brush and carb-cleaner. The results were very good and a year later the finish looks just fine. Needs a good cleaning, though after a winter of neglect.
I followed a tech write-up from AudiWorld as a guide, but substitured the Duplicolor paint for the hi-tech caliper stuff, after reading the experience of others on that board. Take a look for yourself at:
http://www.audiworld.com/tech/ext48.shtml
I did not spray the paint on the calipers. I sprayed small quantities into a plastic cup and used small disposable brushes to apply it. As others have indicated, the paint is very thin and it takes at least 3 coats to get a good solid color (red in my case). I ended up doing 5 coats to get the desired look. I did not dissassemble the calipers to paint then...the job ias fine, but would have been better if the calipers were removed from the mounting bracket.
Regards,
SteveCo in St. John's
Regards,
