Turn Signal Debug - 1991 S4
Hi All,
Trying to debug a passenger's side front turn signal + side marker issue.
Here is the information I have gathered so far, would appreciate any guidance:
- Ignition on + turn signal drivers side active = drivers side turn signal lights all flash correctly
- Ignition on + turn signal pass side active = rear pass side turn signal flashes fast, no activity on front pass side turn signal, no activity on either front or rear pass side markers
- Ignition off + turn signal pass side active = front, rear turn signal and side markers all illuminated and on (so all the bulbs seem to be good - I did replace a couple of these)
- Hazard on = all front, rear turn signal and side markers flashing correctly
Would this imply the relay is bad (looks like XIII)? Part number 111953227D
Thanks,
Mike
Thanks,
Mike
