thats the connector thats used to set the O2 content,
By jumpering 2 of the connections It will shut off the Idle Control Valve,
then you adjust the engine idle with the setscrew at the front of the intake manifold.
Also you will set the mixture with an O2 sensor by adjusting the MAF
