Have any of you seen marks on a windshield like the circled ones in the picture below? I've scrubbed on both the inside and outside and they remain. They don't seem to be on either surface. There isn't any damage I can see or feel on the inside or outside surface either. I'm thinking this must be some kind of delamination. I don't recall if these were there when I brought the car home 10 years ago or not. I suspect they were. Let me know what you think.
This is going to sound nuts, but get some 0000 steel wool and rub that on those spots, dry. It will not scratch the glass, but it may remove that stuff if it's on (and not in) the glass.
Thanks Speedtoys, Rob, Blake and Vanster. The 0000 steel wool worked like a champ. I would not have thought of that or polishing to fix this. On one of my daily's, I'd just get the windshield replaced when it had enough issues to annoy me. That's a bit more painful in the wallet on a 928 windshield with an integrated antenna. Too bad this trick won't work on my ugly dash and pod.
I'm going to try the polishing that Speedtoys suggested on the entire windshield to see what it takes out. I watched a video on doing that and it didn't seem to require all that much trouble.
