Brake fluid reservoir gap
I am trying to install the reservior back into the master cylinder. The seals are in the master cylinder. When I press tbe reservior down I still see a gap. Is the bottom of the reservior supposed to touch the top of the rubber gasket?
Team Owner
did you put dc111 on the grommets before you put them into the MC then some dc111 on the barbs of the tank
