AC idle control valve orientation OB
HelloCould someone please advise which way the arrow should point- to the pipe connected to the top of the spider or to the one that goes to the throttle? TIA
Thanks. Needs to be oriented correctly as it increases idle speed when ac is turned on by changing the fuel /air mix. To your point though makes sense for arrow to point towards throttle which is what I ended up doing.
