Got brake booster in mail
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1920x1920/2021041318425400_d29be6fc9f951358c37ef8c250fffc4bd414ea27.jpg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1920x1920/2021041318422600_c91fbd753d68a7c20f1459369885311a4b0b1727.jpg)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1080x1080/2021041318415900_9030e2572fbce51e08dde1081bd25092b656713a.jpg)
Alright I am not 100% sure we're the rubber gasket goes. It it in-between the master cylinder and the booster? Also do I put grease on the master cylinder piston? Can I install the master cylinder in the booster before installing this?
i don't think you can get the booster in (or out) with the MC attached - if i recall i had to remove the MC then step on brake pedal and clip a vice grip to rod to trap it when it protrudes out on engine side so booster could be shoe horned in and out
Team Owner
make sure to make a protective plate to protect the mating surface of the MC , while using the vice grips.
I use a piece of coolant bottle with 3 holes in it .
NOTE that black O ring goes on the MC to booster interface,
use DC111 on the O ring and the MC inlets prior to grommet insertion this will keep water out of the metal
