928 Forum 1978-1995
Sponsored by: 928 Specialists
Wipers - limited functionality.
Old Apr 4, 2021 | 08:00 PM
Alan's Avatar
Alan
Electron Wrangler
Most 928s have the same motor and they are usually quite long term reliable - get a good condition used one from 928 Intl.
Alan
Old Apr 4, 2021 | 09:26 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
NOTE there should be a small ball bearing in the end of the shaft may the ball has moved off center and it is preventing the shaft from fully seating
Old Apr 5, 2021 | 04:10 AM
thepurpleblob's Avatar
thepurpleblob
Alan
The USA suppliers are not really viable for me (postage costs are eye watering) but I've managed to order one from a UK breaker so we'll see how that works out.
Old Apr 5, 2021 | 03:24 PM
Alan's Avatar
Alan
Electron Wrangler
Douglas Valley? - I've had very good result with them for several ROW config things. Recommended.
Alan
Old Apr 5, 2021 | 03:33 PM
jchasty's Avatar
jchasty
Alan
Steve at Douglas Valley is a real gent - used them many times!
thepurpleblob
Alan
Agreed - I've had a few things off them. They're very good/efficient
Old Apr 5, 2021 | 03:38 PM
murray928's Avatar
murray928
In the UK , luxurycarspares.co.uk are by far the best 928 breakers, very easy to deal with and totally reliable. Ive dealt a few times with their main competitor in the UK and had very bad experience. In the last 6 years since I bought the car, I have saved huge money on everything from a gearbox to sunroof sliders to brake calipers to power steering pump to headlight replacements. Too much to mention really. Totally recommend them. Speak to Rob.
Im just a satisfied customer, no other affiliation.
Old Apr 5, 2021 | 03:42 PM
thepurpleblob
Yep - had a load of stuff off them. Very reasonable prices too
Old Apr 8, 2021 | 10:33 AM
thepurpleblob
Just to tie this up - the replacement motor from a breaker solved the problem with minimal extra hassle.
The whole mechanism turned up so in it went. It's a couple of part numbers newer and for an S4 I think (mine is an S2). The connector is on a little bracket but all I had to do was remove it and put the connector in the existing hole in the casting. Job done.
So, definitely the motor failed on slow speed in my case.
Old Apr 8, 2021 | 11:13 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Glad you got the wipers fixed Keep em flying !
Old Apr 8, 2021 | 12:53 PM
Alan's Avatar
Alan
Electron Wrangler
Good! - thanks for closing the thread out with a clear conclusion to this one - nice to know how it ends up
May it last you a long long time, I assume it will get quite a lot of use (unlike mine!).
Alan
