Front AC somewhat cool, rear AC ice cold
The rear AC is really cold at any fan speed. However the front AC blows cool but only just.
Why would rear AC blow a blizzard but the front is only a little cool? Mixer Flap adjustment? Does the exterior thermistor provide inputs only to the front AC mixer?
thank you.
86.5 928S AT
- Front blower works great
- Repeatedly cleaned ductwork from dash and firewall sides
- All new vacuum lines on the engine side
- New checkvalve near brake booster
- New heater valve (x2 to make sure)
- Heat works fine
- Removed and cleaned the HVAC control panel
- Removed and cleaned the interior thermistor/blower assembly
thank you.
86.5 928S AT
The symptoms suggest hot water is getting past the hot water valves. In my experience the hot water valve is either closed when the car is running or open when it's not. it does not cycle.
My test is to see the front vent temps at startup. If it goes for ice cold to warm as the engine warms up you have hot coolant getting past the 2 hot water valves.
Are you sure the hot water valves are oriented in the correct direction?
And what the high and low numbers? The front expansion valve could be clogged.
Expansion valve clog is an interesting thought.
That's why we need to know the high and low side pressures.
What does the front do without the rear running?
A COLD rear with a "meh" front with both running at the same time is sorta normal.
The stock condenser isn't large enough to run both at the same time with good results.
I'm guessing your foam on the blend doors is no longer present and/or misadjusted and some of the interior vacuum valves are leaking.
Common issues for sure.
You can check to see if the front evaporator is getting cold by sticking a thin thermometer into where the capillary tube from the freeze switch slides into it.
This would for sure tell you if it's working (expansion valve clogged or not as stated above) on the refrigerant side without having to test pressures if you're uncomfortable with doing it.
Most of it comes from a thorough cleaning of the system using BG or something like it. But, a really good AC tech is really important.
Also...
With the AC going feel the pipes at the front expansion valve. They should be ice cold and frosty going into the evaporator.
Kevin
Kevin
