Caliper seal orientation
Rebuilding calipers today. Unsure of correct installation for the outer scraper seal. I believe the top one is the correct way. It has the scraper closer to the rotor face. With the bottom one having the full rubber face facing inside the piston.
The service bulletin in the WSM that specifies a change in scraper seals doesn’t show clearly.
Thanks in advance
