$$$ Reward for 928 timing help...
#31
Resistor wires will not measure continuity... if you set your meter to a the ohms scale, you should get a reading that varies with length. The end connectors also have a resistance.
#32
#33
Mark R ........ I just wish I had recalled that issue of the reversed green / white wires much sooner . The business with the timing ring moving misdirected everyones attention ......much like magic tricks . The question was not how did he make the elephant disappear ? BUT how did he make it appear in the first place ? I assume the check is in the mail ..........
#34
Hey Marc ...Way to go. Glad to hear things are starting to fall in place. Good luck with the dyno trials let us know how you make out.....Cheers
#39
Team Owner
any update?
post 30 tells of swapping the green/ white wire
#42
Team Owner
BRB may be having issues with the timing ring on his flywheel, so thats why I linked this thread ,
I know its old but still has useful info...
a followup on what the result was would also be helpful
#43
Stan, as always, thanks for investing your time to help.
