Another noise at gearbox zone
Dear all.
'89 S4 Auto
I have read all the threads with the word "noise" in the forum and I couldn't find a noise similar to mine. That noise comes from gearbox/diff area, it's rpm dependant and it disappears when the transmission is loaded, I mean the noise only is present in Park or Neutral.
Torque converter and Torque tube bearings were changed 7 years ago (10.000 kms), because there was another noise much worse before the bearings were replaced.
Any suggestions?
Thanks so much
'89 S4 Auto
Any suggestions?
Thanks so much
Noise was recordered just before ATF drain, I have drained TC too (total was 6,5 -7 ltr) but now I am waiting for the kickdown spring, because mine was broken. As soon as spare comes, I will fill the tranny and report again.
I asked the question of noise in case it was important to notice anything wrong with the gearbox now that it was out of oil and filter.
Thank you
Hi folks
ATF service done. 7,5 liters of Dexron IID were refilled.
The procedure I followed was: Motor stopped, I fill the reservoir to max, wait for some minutes, then I start the motor in N and surprise: NOISE.IS GONE
With the motor started in N, I am going refilling the reservoir, NOISE IS COMING, then I switch among D, R, N and P gears for some seconds and return to N. Noise is evident now. I adjust the level to cold mark. Total 7,5 liters.
Noise goes out when gear is in D or R. Noise travels from the torque converter to differential.
May be bad torque converter?, Transmission works fine, no issues except the noise.
Thanks for the comments
Roque
Roque
This is an update of noise.
Starting, the gear is P, a little acceleration for hearing purposes (sound pitch changes), then I change to D (no noise), change to N (Noise), change to R (No noise) and finally, change to P again (noise).
Any suggestions?
Any suggestions?
