Headlight Issue
Team Owner
OK you have an 86 Euro, yes I see your fogs and driving lamps work, I missed that .
try moving the hi beam stalk back and forth after you have sprayed deoxit 100 into the switch contacts.
I had an earlier Euro to fix with the same issue. it turned out that another relay had failed and it took out the feedfor lights on.
Have the relays been removed and the pins had deoxit applied to them?
In my case one of the other relays was failed I thought it was the X bus relay.
So since this didnt fix it (swapping in a new X relay,)
then it would be wise to remove the rest of the relays and test them ,
I was using a 4/5 pin relay tester
I was able to clean up the internals of the headlight relay with some Deoxit today and it is now clean with no signs of damage. I plugged it in and the same symptoms persist. Lights come up and motor seems to work correctly but no power to the lights.
I will clean the 4-connector plug behind headlight motor.
I cleaned up this plug and tried the headlights again. Unfortunately, it did not resolve my issue. I ordered a replacement headlight relay for delivery tomorrow. Fingers crossed. I'd love to find out more about the power situation in the CE panel, though. As mentioned, I had 12.6V to 30a and 30b (picture in post #17 above).
Team Owner
please buy a relay tester from amazon under 20.00 then test the relays
Electron Wrangler
I don't like how the relay looks - the circuit board corrosion to me looks reminiscent of "Tin Whiskers", these are conductive strands of tin growth - they can indeed cause functional problems. Someone has tried to address this. But it may not be sufficient. Acid etching (difficult without damage) or replacement may be the only viable options.
12.6V car off is fine
Alan
Alan
Alan
Alan
