'89 Digital Dash does not light up when door is unlocked
I'm going though some electrical and starting issues and noticed that after I cleaned many of the grounds that the digital dash no longer lights up when I unlock the door or connect the ground strap. It turns on when I turn the key. Has anyone seen this before?
Is fuse #24 good and are the fuses all clean?
I'm not clear on " when I unlock the doors..", the interior lights are on the same circuit, do they all work?
When I unlock the doors, or open them, Usually the interior lights illuminate as well as the digital dash, showing the milage on the left, the avg mpg in the middle, and the triptometer on the right. The cabin lights illuminate correctly when the door is unlocked and opened. However the dash does not light until the key is inserted.
Electron Wrangler
Yes every time - this is how it is supposed to work!
Alan
I'm having some starting issues so I am checking out anything that seems different than before, hence my question.
So based on the video, my battery fluctuates between 8.6V-9.7V during cranking. I suspect that would indicate the need for a new battery, correct? I believe the battery should be pushing over 10V cranking with most cars, though not sure if the 928 has any different voltage needs. Thoughts?
Electron Wrangler
I don't think is a real problem. Normally would be above 9V with a new battery - but likely still has life left as long as it turns over sufficiently fast... I don't think its related to any change in behavior
Reconnecting the battery probably does result in the instrument cluster illuminating during its reboot so that part is likely true.
Alan
Alan
Alan
Alan
Not sure if you can hear my starter in the video, but it sounds sluggish to me. Maybe I should rule out the battery in this case?
I recognize this may not solve my issue with getting the car running, but it may have to be overcome first.
So I found a video I made years ago with the startup sound as well as the one I just took, keeping my phone outside the car. The video with the mic by the exhaust is from 2015 I think. The one I just took has the phone looking underneath the cabin. The starter sounds much different and has an odd clicking noise, which may be the solenoid.
Still thinking the starter may be done for vs. the battery, but welcome your thoughts.
Team Owner
Please read the warnings in the WSM regarding voltage assisting starting on a 928
Not sure what this means^^ but if the battery is in question either charge it up or replace it .
If the Starter is in question remove it and have it tested
NOTE adding jumper cables and an extra charging assist to start the 928 can damage,
the relays on the CE panel, the alternator diode pack and or the V Regulator,
the LH computer and EZK.among other things.
Jason you might need to swap in a new set of spark plugs
Just my 2c. I've worked my way through the electrical system of my girl for the past 10 years. Fixed, cleaned , diagnosed just about everything. Pulled the cluster half a dozen times sorting out some unusual gremlins, got my cluster solved and my electrical system is 100% now. After all this time, the one thing that did the most to solve problems was dead simple.
There are a couple of weak points when these cars get old. Check the main power cable at the multi pin connector on the passenger fender. Everything runs through that baby. On mine, the main lead where it enters the connector was looking tired. Hard insulation for about 1/2 inch. Closer examination and the stranded wire inside was corroded, green and stiff. Cleaned, deoxit and reattach. Instant improvement. But, by fluke, I was under the car and noticed one of the wires on the starter solenoid looked the same. Took it off and it was terrible inside. Stripped it back, new eyelet, reattach and bingo. My running voltage and idle voltage both improved along with some minor engine improvement as well. I have a digital voltmeter and now I'm at 13.4 even at idle. With everything on max power consumption, I'm getting almost 13 at idle. Increased resistance in the old connections and wires cause all kinds of hard to find problems.
Ive had those connections apart over the years for other work but I guess I just wasn't paying attention.
And yes, the digital dash will light up when reconnecting the battery. Every time, does a reset and you get the production code and software info briefly on the display. Otherwise, dash doesn't get energized until you turn the key to position 1.
