is there an idle speed stabilizer on my 928?
Hi all,
Quick one I hope...
Is there an idle speed stabilizer on a 1983 Euro "S"?
If so - where?
also the pipe on the top of the intake plenum - the one on the right hand side - ehat is this? I thought it was just a vapour return?
thanks
JC
Quick one I hope...
If so - where?
thanks
JC
No idle stabilizer. There are an auxiliary air regulator which raises idle speed when cold and a decelerator valve that lets air bypass the throttle when you lift suddenly.
I'll guess that you have an automatic and the line you're wondering about supplies a vacuum signal to the tranny.
Thanks - can you point me in the direction of the aux air regulator and decelerator valve please?
The pipe I was talking about it the other one - the one on the side and not the front.
JC
JC
