hand brake problems
hand brake problems
Hi
My 84 s2 auto just failed its test on a inoperative hand brake.
Basically when the brake is on the car will not move forwareds but it will roll backwards.
The brake shoes are new the discs have just been machined and the shoes and cable have been adjusted correctly.
It seems a weird problem as I thought when the lever was pulled up the car would lock in both directions.
any suggestions or help will be great
Cheers Tim
84 s2 auto
Cheers Tim
84 s2 auto
If what you say re the condition of the parts and adjustment level if the lever and cable, is true then some how the shoes have been installed improperly. Do you have the shop manual?
