I've just replaced a missing pin switch on the lower latch assembly but I am not sure how to secure the switched ground wire. Do I crimp the open sleeve at the bottom of the switch pin onto bare wire? Thanks in advance for any guidance.
Regards,
John
1981 928 Chiffon White over Cashmere A/T (127k)
The switched ground wire is the Brown/White wire, connected at the end (crimped). The Ground - Brown wire can go as shown OR can go to a chassis ground point.
Thanks Majestic Moose! That's what I envisioned.
Can you also help me understand the function of that thin metal piece adjacent to the pin switch? Is it a protective shield of some sort? On mine it appears to have been bent out of position or partially broken. I can bend it easily if necessary.
Regards,
John
That is the actual switch terminal part - when the latch is shut it does not connect to ground (e.g. the frame of the receiver).
