8” H4 Headlight Rust
The local windscreen installers recommended below,
This aquarium safe formula locks out water and forms a durable seal that does not shrink when drying.
- Forms a durable, waterproof seal
- UV and weather resistant
- Excellent adhesion to glass
Chronic Tool Dropper
Challenge with silicone-based sealants is that you'll damage things if you ever need to get the lens off in the future. The vinyl stuff is better. Use the Right Stuff.
TripleMMM (10-14-2020)
You can find really good 3M adhesives at a marine store that are the correct color. I lost a lens a few months back, which tells me that they do get brittle. Also I agree with Rob about using a 3M laminate to go over the lamp. I have a 20 year old Jetta with plastic head lamps. They had yellowed so I used Nuevite aluminum polish to bring them back. I'm sure others will work and then put the 3M laminate over each and they have not faded at all.
