The IAC helps control idle smoothness by metering air, which has passed the MAF, to the back side of the throttle. A non functioning or "sticky" IAC sometimes induces idle "hunting", in bad cases, perhaps "surging". The fueling computer is pretty capable and may have overcome the lack of IAC function. What is your idle at? spec is 775 + or - 25 for the 89 GT.
Q: "What signal does the IACV return to the LH computer?"
A: RPM
"NO IVAC signal sounds like a bad connection or a faulty LH ECU. A common fault. The idle might be OK most of the time, if the idle stabiliser was last powered by the ECU at normal operating temperature.
The problem comes when conditions vary a bit, and the loop would usually adapt the idle. Now it doesn't...............
