86 Porsche 928 - Regreasing Clutch Short Shaft Splines
Hello all.
Without removing the clutch, is it possible to slather on a new coat of optimoly ht (or Castrol Molub-Alloy paste HT???) without removing the entire clutch pack...?
If I pull the cover and undo both of the clamp bolts will the short shaft slide back far enough that I can get some new grease on the splines of the shaft and then push it back in?
I don't think so.
Edit to add:
Besides, you don't want to 'slather' it on.
You want a very thin coating, evenly applied and worked down into the splines.
Too much and even the 'super thick' grease will sling off and get on the friction discs.
Edit to add:
