Mine has been attacked/repaired, in at least three locations, by PO(s) and appears to be extremely fragile. Particularly, the electrical tape they used had fused, over time, to the film. They also broke one of the connector tabs that locks one of the plugs - happens to be adjacent to the “high beam indicator” trace relative to my issue of no high beam indicator (high beam lights behaved).
I carefully replaced the electrical tape but not comfortable with this - a bit sketchy.
I’m not sure whether me removing and resetting the bulb; reapplying the tape affecting the high beam trace; or firmly resetting the plug; but I now have my high beam indicator.
Of course after testing, I’ve now discovered that the passenger low beam and right turn signal are not functioning. I’ll start with the fuses and then...
A panoramic view - before... Under the tape... Under the tape...
Just replaced the foil on my 79 euro with the circuit boards a couple months ago....detailed in my official 79 euro thread. Waaaaay better than the old foil.
