1984 auto no start
Can someone give me some things to check for a 1984 no start. It will start with the fuel relay hotwired but no start with relay installed. New fuel pump relay came from a good source so it is unlikely to be the issue. It seems like it is just not getting the signal to activate.
Here is a thread that might help
https://rennlist.com/forums/928-foru...ay-signal.html
Make sure that you ordered the correct relay (or it’s generic equivalent) for your model year. Here is your fuse & relay chart with part numbers:
https://www.928gt.com/t-8384fuse.aspx
Team Owner
if its a USA version then the FInjection and FPump relays are special,
neither of them are 53 relays
