Help: What is causing this noise
Not from the engine but clutch area.
Car starts, shifts and runs OK.
New parts include OE clutch, Pilot Bearings, recently machined flywheel.
All <2500 miles ago
Please and thanks
All <2500 miles ago
Please and thanks
Team Owner
did you install a new release arm bushing?
whats the condition of the TT?
remove the lower bell and inspect the front TT bearing,
it should be about 12 inches down the TT
Thank you Mrmerlin. All TT bearings were replaced within the last 2500 miles
Were you referring to #8?
I already have a new arm and guide tube to install at the same time.
I thought maybe something that was turning was touching something else.
I will follow your suggestion and report back.
Thanks again.
Thanks again.
Team Owner
maybe one of the TT bearings has migrated.
with the bell off check the guide tube bolts.
#8 is the release arm bushing.
I hope your release arm and TOB and guide tube are all matched parts
