HVAC setting motor and AC button not working
Not sure if there is a relationship between these two, but neither one is working. Fortunate to have another car nearby and I was able to do some swapping of components for testing:
HVAC control unit, AC switch/button, outside air temp sensor and inside air temp sensor all test good. (fuse #6 is good)
My next step is to remove and clean setting motor, and perhaps that will remedy that issue, but pretty sure the AC button gets power directly from the control unit and not the setting motor?
