Hesitation to Start - '92 GTS
My 92’ GTS hesitates a bit to start. Both from hot and cold. I need to push the accelerator for it to start. When I push the accelerator it starts right away...
Any pointers?
Any pointers?
Put a bottle of Techron in the gas also 6 oz of MMO and 2 oz of Startron do short drives see if it improves
also pull the vacuum line off the front damper smell for fuel
if you smell fuel then it might be time to replace the dampers and the FPR
Note the chemical concoction is less expensive to free up dirty injectors
The injectors were cleaned, new filters etc not very long ago. Do you think its a leaking injector issue?
If you have to press on the accelerator pedal to get it to start, that means it could be over-fueled at start-up. Potential causes off the top of my head:
- pressure dampener or regulator diaphragm broken thus allowing pressurized fuel to squirt through the vacuum lines and into the air guide (as per MrMerlin above.)
- leaking injector(s)
- wrong type of injector
- LH on the way out (if original un-rebuilt.)
Will it *never* start unless you press the go-pedal? Or does it just take longer to start if you don’t? The distinction between these two characteristics determines next steps.
I tried tried another LH. Same issue.
If I dont press the accelerator, it will hardly start.
Injectors are the original ones.
I will take off the MAF and look for Fuel in the intake.
Don't forget the Temp II sensor and connector. If the wires are split under the boot and touching you will get a default rich condition.
